Question about Apple iPhone Cell Phones
Iphone not charging - iPhone Apple Cell Phones
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Try another charger if it still not charging the problem is the phone. You will have to have it looked at by a repairer.
Posted on Apr 24, 2015
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
My iphone 4s will not charge
have a look at the port on your phone were u put the charging cord and see if the we part inside is broken or cracked and do the same on your power cord if u cant see anything wrong and u cheep u can always buy parts for them and take apart your iphone and replace the power socket
Aug 03, 2012 | Apple iPhone Smartphone
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
IPhone Smartphone: cant charge iphone in ibiza battery went flat...
Possible solutions
1. buy an adapter for your charger
2. plug it into a computer
3. provide more details than you have so far...
can't charge iphone is a vague way to explain your predicament...
can't charge or won't charge?
can't get an adapter?
don't have access to a computer?
Half solution, half clarification request...
May 16, 2010 | Apple iPhone Smartphone
I can't charge iPhone, I got power surge warrning on my computer
hello friend,
maybe your cable of charging is nit genuine,
if warning displays in your phone then there is the problem in cable
and if the error displays in computer then the problem should be in battery or main board
Apr 22, 2010 | Apple iPhone Smartphone
Why doesnt my iphone charge when its on but it charges when its off?
This is not the normal behavior of iPhone. iPhone should charge regardless if it's ON or OFF.
What's happening is that the battery is being by-passed when charging it while the phone is ON. There could be a possibility that the battery could be faulty or there are components that needs to be replaced.
If the phone is still under the warranty, kindly contact the manufacturer and have them repair or replace the battery for free.
Good luck and have a great day!
Jan 05, 2010 | Apple iPhone 3G Black Smartphone
Sometimes my Iphone will not charge when i connect it to the wall charger. I just bought my iphone a couple of months ago.
If your iPhone is not charging when you plug it into a wall charger or into you computer's usb port, this is a usb connectivity issue and the connection just needs to be reset. All that needs to be done is plug the iPhone's cable into the phone but don't plug into the computer yet. Hold the phone's select button (the round button with the square) down for about 30 seconds or until the apple appears on the screen. your phone will reload and reset the connection and the computer should recognize the device. Allow the phone to charge for at least 30 minutes before unplugging.
Oct 21, 2009 | Apple iPhone Smartphone
My iphone wont charge
Trying using the wall charger.
Aug 01, 2009 | Apple iPhone Smartphone
IPhone not charging, not recognized
You need to restore whit the last version of iTUNES and an ofiial firmware. Then apply jailbreak.
Apr 14, 2009 | Apple iPhone Smartphone
Cell Phones Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
