Question about Coffee Makers & Espresso Machines
I cannot remove the "general alarm"message. I have done everything the book says to do, any ideas
2 Suggested Answers
  • 30 Answers
SOURCE: Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
Posted on Jan 29, 2012
Can't create new messages and create new contacts.
If Outlook says it's corrupt them you gonna have to create a new one.
Try to do a backup of everything by doing a Export from Outlook to backup.pst
If this doesn't work then you will have to re-create your Outlook client and YOU WILL LOOSE YOUR E-MAIL INFO.
Or,
Go to TOOLS->EMAIL ACCOUNTS->VIEW OR CHANGE EXISTING ADDRESS BOOKS OR DIRECTORIES and remove the "Personal Address Book", then restart Outlook and see if you are still getting the error message.
Try to install Recovery Toolbox for Address Book http://www.outlookexpressaddressrecovery.recoverytoolbox.com/
Read here about file corruption: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook-express/525-got-a-problem-with-outlook-express-what-to-do
Nov 19, 2014 | Microsoft Outlook Express
Dishwasher not completely drained and alarming
If this is an F11 mile dishwasher problem please do not make the same mistake as us and RECHECK the non return valve thoroughly. We had checked this before calling out the engineeer only to be charged 75pounds (as it was still under guarantee) instead of the normal 117pounds A tiny shard of pottery had become trapped, which my husband had not seen (when he took the non return valve out of the machine). After this was removed the dishwasher was fixed at an unneccessary cost of 75 pounds. A very expensive mistake indeed especially as we thought it was a pump problem and we had done everything by the book to sort the problem ourselves.
Feb 01, 2014 | Miele G 1472 SCVI 24 in Builtin Dishwasher
Aplique alarm 6 14 keeps coming on randomly
The only alarm system I've had is my 12ga with deer slugs.
It shouldn't be too hard to either turn it off, or find the problem power supply. I am thinking the power to the house may have blinked off and on at some point, and the logic of the alarm is freaking out as a result.
Is there a backup battery for the alarm system? If not you could try turning off a circuit breaker at a time until you diagnose which one is powering the alarm system. If you find one that turns the alarm pad off. Leave it off for a few minutes and turn the breaker back on to see if it will reset itself. If the alarm has a battery backup try to remove it and again turn off the circuit breaker. Also search your book for resetting the alarm system.
Dec 01, 2011 | Cars & Trucks
How to print out face book messages?
Sign in to Facebook on a computer and go from there. Everything you do on Facebook Mobile is done on the main site.
All your messages on your phone, through facebook, will show up on the desktop site when you sign in
Sep 10, 2011 | Apple iPhone Smartphone
I have hiot a button or something and i am not recieving text messages and also i have 5 emails i cant find. helppppp I am so new to this phone and everything was working fine until i tried to erase some...
To receive messages please follow the steps:-
1) Go to Options.
2) Select Security Options.
3) Select Fire wall.
You will find Block Incoming Messages, Kindly un check all the boxes and save that and you will be able to receive all the messages.
As you said that you are not able to find emails. this happens because the email service book might got corrupted, So kindly delete the email service book of your Handheld and contact your service provider to send a new email service book for your Handheld then you will be able to view all the emails in your a/c.
To delete the email service book follow the steps:-
1) Go to Options.
2) Select advance Options.
3) Select Service book.
Under service book you will get ( CIMIME) and (CICAL) delete this two service book.
I hope I was able to help you.
thank you for using Fixya.
Nov 21, 2009 | RIM BlackBerry Pearl 8100
Constantly flashing Hazard lights
Faulthy sensor or a relay, try to reset, by dis/re-connecting the ground cable from the battery, remove the ground cable ( - not the +) wait 1 minute reconnect the ground cable.
Jul 13, 2009 | 2002 Mercedes-Benz C-Class
Hy is my blackberry pearl not showing who my message is from
Cause:
  • Number is not saved in the address book
  • Issue with the setting in the handset
  • Software issue
Resolution:
  • If the name is not saved then saved the name in the handset
  • In the handset go to Call logs -> Menu -> Option -> Smart Dialing -> Country Code is +91 and Option ->Security Option -> General Settings -> Include Address Book -> Yes
  • If the above two option is done then re-install the software.
Jun 18, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
I am getting a service error 5100.
There is something blocking the carriage from seating home. 5100 generally means there is either something in the paper path or an obstruction in the ink carriage path. Open the clamshell to look at the carriage path and make sure the cable connecting the carriage is not restricted.
Apr 19, 2009 | Canon PIXMA iP1600 Printer
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
