Question about Kenmore Refrigerators
How do you change part MJU62711401 hose from a kenmore model# 795.70323.310?
The hose has a big hole in it.When you go to get water, it blast a hole in my dry wall from the back of the frig from the hose with the hole. It also ruined my bamboo flooring.Need to know how to remove the old hose and put in the new one.
  • Kenmore Master
  • 5,323 Answers
YOU SHOULD BE ABLE TO SPLICE IN TO IT WITH A CONNECTOR IF U CANNOT REMOVE IT WHOLE? JUST BUY AND ADD A COUPLER CONNECTOR, THEY USUALLY JUST SNAP ON AND OFF
how do you change part MJU62711401 hose from a ken - 25638114-5dbacpjug1urbtduyx4ujsps-1-0.jpg
25638114-5dbacpjug1urbtduyx4ujsps-1-2.jpg how do you change part MJU62711401 hose from a ken - 25638114-5dbacpjug1urbtduyx4ujsps-1-5.jpgt/uploads/images/25638114-5dbacpjug1urbtduyx4ujsps-1-5.jpg" alt="25638114how do you change part MJU62711401 hose from a ken - 25638114-5dbacpjug1urbtduyx4ujsps-1-9.jpg"h_mi" />
Posted on May 17, 2015
  • 42 Answers
SOURCE: REPLACING FRIGIDAIRE FRS26H7C ACTUATOR
darlenek,
There is a trick of sorts. If you go to the bottom hinge of the freezer door you will find the same tube. Pull carefully and give yourself as much excess tubing to pull up through the door. Do not pull too hard or too much. This will give you more slack on the top end to work with. Once you get it reinstalled in the hole in the bracket, you probably will need to pull "carefully" back down through hinge to reinstall the dispenser bracket assembly.
I hope this helped you.
Please don't for get to rate me if I have helped.
supertechks
Posted on Jan 26, 2008
stephanos18
  • 144 Answers
SOURCE: the hole that drains water away at back of fridge is blocked
Ok you need to defrost this unit eg unplug and leave all doors open for 48 hours then get some "flexy curtain wire (white plastic coated, used for hanging net curtains) this wire is perfect for getting up or down the fridge drain.
Please rate my advice
Posted on Mar 25, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
  • 78 Answers
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
Posted on May 03, 2009
mgprice
  • 744 Answers
SOURCE: water is pooling under the veggie bins- watere
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Sep 12, 2009
My Kenmore ultra wash dishwasher does not drain all the time. I am now stuck with water in the bottom and has gone through the whole cycle.
The MOST SIMPLE, first thing to check is the drain hose. disconnect it at both ends and BLAST water through it to clean it out... or replace it if it looks questionable...
Mar 03, 2016 | Kenmore Dishwashers
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Water leaking from top of kenmore refrigerator model 253
Almost certainly a blocked drain hose. Hose can usually be accessed from the back, it drains to a catch pan, usually on top of the compressor/motor. Best unblocked with a blast of compressed air if you have a compressor otherwise feed a long piece of whipper snipper chord or similar up from the bottom to dislodge the blockage (and/or down from the top if you can access the drain hole from where the leak appears inside the fridge). Good luck, hope this helps.
Nov 15, 2013 | Kenmore Refrigerators
Kenmore washing machine will not drain water /spin cycle
There is likely an object (like a sock) lodged in the drain hose that runs from the tub to drain pump. It could be in the hose in which case a squeeze will verify, or jambed against the drain pump impellers. It could even be between the inner basket and outer tub covering the drain hole. Regardless it is usually easily retrievable with a little ingenuity as well as a little to big mess of water. So prepare for the water if you losen a hose. Unplug the machine before you start because electricity and water are never a good combination. A wet dry vac works good to remove standing water in the tub and you can even hold the nozzle over a loosened hose to remove water from it as it pours out. Let me know if you run into difficulty.
Jan 11, 2013 | Kenmore Washing Machines
Water leaking out of steam hose
If the water is leaking out from the steam hose, there are only a limited solution which you can use to tackle this problem.
First you have to locate the exact point from which the water is leaking out. If you have located the point, you can now go on to check if it happens to be a big hole or just a tiny hole, this will help in determining the method you would use to deal with this problem.
If the hole happens to be a big one, it is best advised that you just change the whole hose because patching large holes are not very good and they could prove to be useless at times.
Also, you can do one of the following if it is a small hole where the water is leaking from.
You can decide to patch it using some sort of adhesive or use other methods that you feel would do about the same job.
Alternatively, it is still best that you change the entire steam hose. This might require you to call a technician or an expert to come home and help you examine it properly and then fix it for you.
It shouldn't cost too much to fix it or change the whole hose.
If you want to change it by yourself, you can go over to a local store or shop online for a replacement one.
Hope this solution was helpful to you? Please comment for more information and thank you for using fixya.
Jan 16, 2011 | Electrolux EW1209i Front Load Washer /...
I have a Kenmore model 70 washer, I changed the mixing valve, and now the washer is overfilling, and will continue to flow water. causing the washer to overflow,
Check the small air hose on the pressure switch inside the operator console. The following link explains:
http://www.fixya.com/support/r3575901-washer_overflows
The hose can sometimes come loose when doing maintenance, or from years of vibration. If the air hose is intact, check for any splits, cracks or holes in the air hose. If the air hose is not air tight, the pressure switch will never detect the water pressure differential from the wash tub as it fills. If it never detects the pressure, it will not shut off the water inlet valves.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate under the wash tub rim under the lid) and let me know. I hope you find this information helpful.
Dec 16, 2010 | Kenmore 22422 Top Load Washer
My kenmore elite keeps showing f20 near the end of my wash cycle
f20 can be your fill a fill hose problem, flowmeter problem.
But first i want you to check you hoses
turn the water off
take the hoses off the back of the washer
get a bucket
put the hoses in the bucket
turn the water back on...one at a time so that you don't get blasted with water.
Do both hot/cold come out with good pressure?
If yes try
take your lid off the washer between the inlet valve and your dispenser is there a white plastic piece one end going to the valve and one to the dispenser.
IF yes take it off and blow through it.
put back on and see if the code comes back
If yes
Then it is possible you may have a bad pressure switch.
let me know how it goes
if you take the kick panel off by removeing the t15 torx screws you will find the tech sheet to help you
Jan 11, 2010 | Kenmore Elite 45986 Front Load Washer
Water leaking inside refrig below ice maker
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 22, 2009 | Kenmore Refrigerators
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Refrigerators Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
