Have good fuse at inside cabin fuse block. Good also at under hood fuse block.
There is a separate fuse for the jack located in the fuse box labeled accessories this probably problem
Main ignition fuse is only for just that...
if you checked that the circuit to that power outlet is OK, including the wiring, maybe the jack itself is bad
disconnect it, then use jumper wires to the battery to see if it powers on
Sold the truck last fall.
