Question about Exercise & Fitness
Tread belt is creasing. Have tried to adjust but continues to crease
    New Friend:
  • 52 Answers
Belt is not aligned properly, have to be exact or belt will crease. If new seek warranty support. good luck.
Posted on Apr 10, 2015
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
The belt on my NB 1400 treadmill has folded over and I cannot undo the crease, even if I loosen the tention.
1) try to adjust see the videos and proceed according at your common sense NOT feared:God bless you
Jul 25, 2012 | Exercise & Fitness
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
The belt on my New Balance 1400 has become kinked up. I tried adjusting it by loosening it up, straightening it out, then tightening it back up, but it kinks up again. Before it kinked up for the first...
Unfortunately once the belt has a crease that all she wrote. Belt replacement is the next step.Call Fitness Quest they are the makers of your treadmill @ 1-800-321-9236
Jul 31, 2010 | New Balance 1400 Treadmill
I have an Image 15.0Q UMTL31504 and the belt has
Go To Iconservice.com Click on manual input Image then M# IMTL31504.
Check the end caps to see if one of them is cracked before adjusting the belt. The crease cannot be straighten and 9 of 10 times it can be a hazard when walking so if you proceed using it in this condition BE CAREFUL!!!
Jul 30, 2010 | Exercise & Fitness
Running belt has creased badly, will I need new belt ?
Wow, this is weird, I've just come back from the gym and the guys there were 'fixing' a crease on one side of the belt.
They had the belt off the treadmill, and put a wooden board on the inside, with some weight plates on them, a few wooden blocks on the inside, so the belt looked like it was the same height as when it is fitted and then a wooden board and weights on the top.
By the time I'd finished my session, they were refitting it and it looked good, you could still see a slight dent, but not a full crease.
Hope this helps you and good luck.
Jul 18, 2010 | Tunturi T30 Programmable Treadmill
On my oki 5150 the printed paper develops a crease usally in the middle of the page. Usually about 4 inches long, with a small overlap that ends up in a crease ... it's starting to get sufficiently bad so...
If the paper under the crease has print and the fold is "glued down", it is most likely to be a problem with the fuser. Try removing it and look for evidence of warping in the pressure roller. If the fuser looks clean and tidy, go to the other end at check over the paper tray and paper feed mechanisim. It is possible the paper is catching on something at the start of the process. This is most likely if there is print over the crease but not under the fold.
Jan 01, 2018 | OKI C5150n Led Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Walking belt folds
It sounds like one of the adjusted bolts or endcaps that adjusts the walk belt is broken,look at the bolts where you adjust and see if the side the belt is shifting to is broken.It may have ruined the belt also but you wont be able to tell till you correct the tracking problem.
Jul 18, 2009 | Proform Sport 1000 Folding Treadmill...
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Exercise & Fitness Logo
433 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
