Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
My side b side fridgidaire will only make cube ice now not crushed
    New Friend:
  • 52 Answers
Fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Posted on Apr 10, 2015
My fridgidaire side by side only dispenses crushed ice even it the setting is at cube. What is the problem
there is a c clip on the solenoid that pulls the rod up to change from cube to crushed its behind the plate on the back where drive motor is
Sep 10, 2011 | Frigidaire FRS26R4A Side by Side...
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Ice dispenser crushes ice when cube is pushed
the little gate/door, is a common issue, its a solenoid htat either burns out, or merelt freezes over. if you put your finger into where teh "shepard hook" supposed otgo, can you freely lift it ip and down???i would assum not, .the entire ***,bly lifts out of freezer( remove 2 1/4 inch scres under each corner and diconnect apower plug behind the ice maker. from ther you can try to defrost teh piston,if not rplace it.
Jan 02, 2009 | Frigidaire GLRS267ZA Side by Side...
Ice maker stuck on ''crushed'' ice
i think it's simpler than that. there's a plastic gate that snaps UP for cubed and DOWN for crushed.
When you remove the tray, set it to CRUSHED, BEFORE putting the tray back in place.
Nov 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
110 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
