Question about Weber Baby Q Grill
Brand new with brand new one pound Coleman canister. Spent hours trying to get it lit. Seems like lp is not coming through. Removed canister and replaced many times. Dont smell lp.
  • 494 Answers
I'd recommend bringing the grill and disposable canister back to the place you bought it and have them look at it or replace it.
Posted on Apr 15, 2015
    Top Expert:
  • Weber Master
  • 46,643 Answers
If you got the cannister from the shop with the grill the chances are that the cannister needs filling first as gas bottles are empty when new.
Posted on Apr 10, 2015
I need to download manual for keystone passport 2008 285rl
make sure battery disconnect is on not off make sure fuses are good in converter and blow out fridge LP system and hot water heater burners cob webs and make sure LP is on and LP detector is good
May 08, 2016 | Keystone 2008 Passport 285RL
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I have brand new coleman mobile home furnace model # DGAH056BBSB the pilot light (elec. Start) wont stay lit and it blows COLD AIR! PLZZZ HELP Ohio is COLD
here, the last sentence is important.
http://www.ehow.com/how_5615197_light-coleman-furnace.html
Further information here.
http://handymanwire.com/ubbthreads/ubbthreads.php/topics/28213/Pilot_light_won_t_stay_lit
But if the unit is new, it must be under some sort of warranty from Coleman and from the fitter.
coleman website, support, contact and warranty, but the website doesn't list, heaters, or furnaces? I am puzzled.
http://www.coleman.com/warranty/
Oct 23, 2015 | Coleman Heating & Cooling
We've had our roadtrip lxe for 3 yrs. We live in Tucson Az. and it works fine here. When we go to the mts. in northern Az. it has failed us every time (9 times). It will light and run for about 15...
Gary & Millie, the mountains you're visiting, must be over 2000 feet above sea level and that's what's affecting your gas grill.The lower oxygen level and lower air pressure affects propane fueled grills. On larger gas appliances, the gas pressure can be adjusted to overcome this problem. But, I don't believe you can do that on a portable gas grill. My best suggestion is to contact Coleman Customer Support at 800-835-3278, to find out if they have another regulator that can be used in high altitude applications.
Good luck and Happy Grilling!!
Apr 19, 2011 | Coleman Roadtrip Grill LXE 9949-750
I bought the tb100 30K-55K propane heater I hooked it up to a fully filled 20 pound (5 Gal) propane tank and it ran fine for about 45 minutes then the burner shut off. I restarted the heater per the...
Make sure that the thermocouple is well into the flame. Check to make sure the other end is secure into the gas valve. Check for any poor connection both gas and electric. If the LP cylinder is icing up, it is a vaporizing problem and the heater is sucking the available gas out of the cylinder faster than it can vaporize. You will need a larger cylinder.
Nov 25, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
How to get the update working
dont bother trying to update the firmware on the router - i spent hours trying this. there is an issue with the netopia routers and your better off buying a new one. lots of people have more routers than they actually need. ill sell you a brand new bt voyager one for 20 euro. 0863303753
Jun 20, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Weber Baby Q Grill Logo
252 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
