Question about Radio Communications
Can you disconnect 1of 2290 pills on the Galaxy 95t and will it still work ok?
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
It will still work but you won't be able to tx or dx and shortly after turning the radio on it would probably smoke something because of too much power going through it , etc.
Posted on Apr 15, 2015
4 Suggested Answers
anymhz
  • 500 Answers
SOURCE: SWR METER ON MY GALAXY 95T GOES BELOW ZERO
check it with an external meter to verify. if showing different.cb shop temple, tx on yahoo search. would take it to a shop to have the swr board redone. or could just be a simple pot.. even from factory they have problems.
Posted on Dec 08, 2009
anymhz
  • 500 Answers
SOURCE: Galaxy 95T
check SWR's check to make sure ALL coax connectors are tight. and if still doing it. may be loose connection in board. but the export style radios go crazy like that when coax is loose or have bad grounds. due to there floating ground circuit design. there not the same as a cobra were its case is ground.
  • 10 Answers
SOURCE: modulation lamp does not light when i talk.
are u talking bout rf meter or tx light
Posted on Mar 11, 2013
My starlight back lighted face plate on My galaxy
typical failure. There is a high voltage inverter that power that, and it sounds like it has failed. It's not a simple replace part A and it works
Sep 09, 2014 | Radio Communications
No front panel illumination
is your dimmer switch turned on or off.
Feb 07, 2013 | Galaxy Radios DX-95T Base CB Radio
My 95T will recieve fine but it don't transmitt, what could be the problem?
finals my be bad you will have to bring it to a electronic repairshop for twoway radios to get it repaired unless you know how to test and replace power transisters
Jun 13, 2009 | Galaxy Radios DX-95T Base CB Radio
Talkback sqeels when it decides to work!
the squealing you are referring to is usually due to to a disabled automatic modulation control circuit.
one or more dry solder connections could cause the intermittent operation.
May 22, 2009 | Galaxy Radios DX-95T Base CB Radio
SWR METER ON MY GALAXY 95T GOES BELOW ZERO WHEN TESTED
May 11, 2009 | Galaxy Radios DX-95T Base CB Radio
Tparsenault
OK I remember a similar problem with a connex radio. It seems the driver's fm radio speakers where picking up some signal even with the fm radio off. Shortening the speaker wires helped some, also make sure you don't have any wire or coax coiled up anywhere. Thats about all I remember, hope this helps.
Tp
Feb 05, 2009 | Galaxy Radios DX-95T Base CB Radio
Galaxy 95T
Feb 03, 2009 | Galaxy Radios DX-95T Base CB Radio
Magnum omega force s45 cuts out
Im a Galaxy man myself and I swear by them .Looks like youve got more than enough power. The mosfets shouldnt have any effect that I recall but be aware that most new C B Radios are going to Mosfets Galaxy being one of them' because of transistors like the 2290 being hard to find and expensive. $20 + a pop.
Feb 26, 2008 | Magnum OmegaForce S45 CB Radio
Radio Communications Logo
109 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
