Question about Siemens WTXD5300US Electric Dryer
What is causing my electric dryer to stop running after 5-10 minutes
Does not matter what setting I try I get the same results.Please help,thanx
  • Siemens Master
  • 2,992 Answers
I presume that after it has "cooled" it starts and runs again? If so, the air circulation, perhaps the vent is clogged and needs cleaning. The high heat protection device is "cutting out" when the temperature gets too high to prevent disasters.
Posted on Apr 10, 2015
The dryer starts and works for about five minutes and then stops and starts beeping.
Is the fluff filter clean? if not it could be causing it to overheat and shut off.
Dec 22, 2012 | Miele T7744C Dryer
The control button on the Whirlpool Duet Dryer is permanently on. As a result, we are not able to start up dryer. We have unplug dryer for 5 minutes with no positive results. We have also tried holding...
Hi
Press and hold the CYCLE SIGNAL/END OF CYCLE button for 10 seconds to unlock the controls. Hope this helps...please post back for further assistance.
Daniel
Jun 11, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
GE elect dryer is cutting off prematurely after 10-20 minutes no matter what setting on timer we use. I'm guessing it's a heat sensor but i don't know where it's located. Model #...
It could be a high limit overload, but the cause may be a blocked air vent. You can remove the dryer vent in the back and see if the problem stops, this will tell you if the vent is blocked or not. Ryan
Jun 02, 2011 | General Electric Dryers
My dryer runs about 30 minutes and then will shut off. After you give it a minute to it will turn back on but when it is in constant use it happens very frequently. It doesn't matter what heat setting it...
sounds like the safety thermostat (Hi Limit Thermostat) is cutting your dryer off. This usually happens because of hi heat (higher than normal) which is caused by clogged exaust.
Check your dryer vent to ensure that is is completly free of lint. Clean the lint from the lint trap all the way to the output of the exaust outside your dwelling, ensuring the dryer has a unobstructed flow of hot air.
R/Jim
Feb 16, 2011 | GE DBXR463EDWW Electric Dryer
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Kenmore 62602 Electric Dryer
DRYER SHUTS OFF ON HIGH SETTING- FINE ON LOW HEAT
lets start simple on this,first check your dryer vent for obstructions(mainly lint build up,)also check the weather flap (where your unit vents to the outside)this should swing open when the unit is in operation.either one of these can cause excessive heat build up in the unit.(this will cause the thermal limit switch to shut the unit down)thus keeping you from setting your clothes on fire.hope this helps,thanx for using fix-ya
Nov 25, 2008 | Dryers
Error Code F2
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Oct 02, 2007 | Kenmore 84072 Electric Dryer
Dryers Logo
88 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
