Question about Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103
Can I use pn # 8534952 in model # 665.138.33K601
NEED PART NUMBER FOR STIHL LEAF BLOWER MODEL BR380 FOR THE BACKBOARD PAD REPLACEMENT
Previous model PN 4203 790 8001
Current model PN 4203 790 8003
May 25, 2015 | Stihl Garden
I am looking for the drum size for a kenmore dryer model number 66702692
29 inch dryer... Drum PN 695587
If you need parts here is the link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11066702692/0582/0151200?searchedModel=66702692&blt=06
Belt is 5 ribs and 94 inches long. PN 660996
Substitution: PN 341241
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Kenmore Dryers
My powerhead drive belt to the N137A electrolux model has broken. I have a new belt for replacement but do not know how to install.
Turn the PN bottom up. With a Phillips screwdriver, remove the six screws in the base. Turn PN over and lift back of cover, then gently manipulate it until it comes off.
Slide the belt off motor shaft, if necessary. Remove the screws on each end of the brush and lift the end of the brush so you can remove the belt, if necessary. Place new belt on brush and place brush into slot. Replace screws and tighten. Pull belt back to motor shaft and slip on. Check belt for tautness. There should be a little play, but not much. Make sure belt is placed correctly and rotate brush a few turns.
I recommend cleaning the inside of the PN while you have it apart. Use the dust brush to vacuum as much as possible out.
Make sure the light cover is in the correct position. Carefully place front lip of PN cover into slot in front.of the PN. Carefully settle cover in place. Check around the PN to ensure cover and base are correctly placed. Turn PN over and replace screws, short one in front.
I do recommend letting a trained Aerus Electrolux tech do this, especially since the belt will have a one year warranty if he/she does it. Of course the belt should last longer than that, anyway.
Mar 03, 2011 | Electrolux Epic 6500 Vacuum
Deive gear is gone. Where can I order one for a model m30016
I found an IPL for your saw here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Your saw Illustrated Parts Breakdown
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_PL.pdf
Item 18; pn 113004-01; Sprocket Gear changes to pn 122513-01; Price $24.
Item 19; pn 059606-02; Drive Gear Price $7.25; Back Ordered - forever?.
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
pn 122513-01; Sprocket Gear Kit (pn 113004-01, 075676 (Bearing) & 059606-02) ; $18.99 Appears to be available. I would waste little time ordering this.
You could have added this to your previous question as I asked. Then I could have provided a complete answer and my rating been Very Helpful, as this one should be. It can still be changed, Ratings and a few kind words are our only payment. I probably invested 1.5 hours getting to this point.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 05, 2010 | Remington Electric Chain Saw
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
Lou
Mar 06, 2010 | McCulloch Garden
Remington 14" electric chain saw (model 075762J) does not get sufficient electric power to rotate
I went here and entered your model number.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
Clicked on the "IPB" link and found
Item 3 - Armature, pn 100933 $60.34 BackOrdered with no delivery date.
Item 9 - Field, pn 098042-01 $48.76
Item 4 - Bearing, pn 075676 $5.60
Item 10 - Gear, pn 059606 $7.25
Item 11 - Internal Gear, pn 107713-01 NoLongerAvailable.
I would inspect Item 11, I think you will find it failed and is not allowing the motor to rotate. It is also likely the brushes (part of Item 9) have worn away. Least likely is Item 3 is defective. Your unit is either not repairable or will cost in excess of $50 to repair. You can try an Internet search for any needed parts not available at RemingtonPower, we can do no more.
RemingtonPower has stopped all production. Many replacement parts are no longer available. If you can repair it today the next time parts are needed e-Bay may be the only source. I recommend you apply the money toward replacement with a name brand unit you expect to be in business for 10 years or more.
Please do not punish me because you are unhappy with RemingtonPower. I provided a very good answer; although probably not what you wanted to hear. HTH
Lou
Dec 18, 2009 | Desa International Remington 14" Electric...
Homelite chaine model # av27 need sprocet belive part # upo6967
Your saw is probably a 27AV. They can be found here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Type "27AV" in the "Model Name/Number:" window, click Search.
10 different models appear match the UT-108?? number on your saw.
I chose one of them, chose item 26 (pn UP06967) on the "Clutch-Chain Brake-Drive Case Cover" detail, clicked "Add to cart" they are $15.60 (new pn 000998263 it now includes a bearing). HTH
Lou
Sep 28, 2009 | Homelite Garden
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Toshiba ct-90157
What is the model# you own, for your TV along with yout satellite system box? MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
87 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
