Question about Ovens
Why does it go off and flash F 2 and go off - Ovens
  • Ovens Master
  • 5,323 Answers
Oven comes on and off intermittently or heats very little:
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
why does it go off and flash F 2 and go off - 25638031-iys1iwg4rgvprz2dtg5bqcso-2-0.jpg
why does it go off and flash F 2 and go off - 25638031-iys1iwg4rgvprz2dtg5bqcso-2-5.jpges/25638031-iys1iwg4rgvprz2dtg5bqcso-2-5.jpg" alt="25638031-iys1iwg4rgvprz2dtg5bqcso-2-5.jpg" class="h_mi" />
Posted on May 11, 2015
Ge Model Number JPK27WOW1WW - Flashing F3
Please confirm your model number as I only find a JKP27WW1WW.
Thanks
Dec 05, 2014 | GE Ovens
Keeps shutting off, flashing S3-Magcurr
replace 20 amp fuse and test oven with amp probe around brown wire on the right side of oven. should have +-14amps.
Apr 15, 2010 | TurboChef C3 Single Oven
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
Preheat light goes on then start flashes then F1 flashes
F1 is an indication of a faulty control board, you can try unplugging for a bit, relpacing control if htat doesnt rectify, the parts not repairable, only replacable
Dec 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Flashing "F2"
hi thanks for the question. F2 means a high temp, and to look at the oven sensor circuit.I would replace the sensor. not too expensive and try . the other solution is the circuit board. so try the sensor. thanks the appliance doc
Sep 29, 2008 | GE Profile JTP18 Electric Single Oven
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Oven fan
Helt, there was a service flash on this model having to do with a wire in the wiring harness not made to specifications. Now, Im just going by the model number posted. Depending on your serial number your model could be included. What it sounds like is that your fan limit switch is gone wacky. This is located in the rear of the oven and tests would have to be done to determine if that switch is closing for some reason. There were other service flashes on this model concerning the thermal cut out mounted just below the vent causing it to open during cleaning. You might want to call for service and see if your appliance is covered under these service flashes. Catriver..post back.
Feb 10, 2007 | Whirlpool RBD245PD Electric Double Oven
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
