Question about Jeep Cycling
My grandson has Jeep Comanche 20" bike, the chain came off and I took it off to untwist it, can't figure out.how it goes on the rear Derailler. I cant find a Diagram Anywhere to put it Back on.
    Top Expert:
  • Jeep Master
  • 50,511 Answers
Go google and type chain arrangement for derailer operation
regardless of the make any diagram of a derailer will be the same
Posted on Jun 11, 2015
wavoconqueso
  • 57 Answers
SOURCE: CHAIN REPLACEMENT
I think I can help. Place one end of the chain over the rear gear (doesn't matter which one, the biggest) and adjust the lever or twist ring on the handlebar so the derailleur lines up in a straight line with it. Pull the chain from the rear sprocket down and over the pivot wheel and back over the bottom wheel so it looks just like this S and the end comes forward. Join the chain links. Place the chain over a couple front teeth and turn the pedal carefully until the chain seats on the front sprocket.
Posted on May 07, 2009
  • 1138 Answers
SOURCE: cant get rear hub back together
Try going to www.sheldonbrown.com/repair/index.html. I think what you need is there. Hope this helps.
Posted on May 23, 2009
  • 484 Answers
SOURCE: i just need a diagram of the rear hub on a coaster brake bike
Park Tool's website has a bicycle repair section and it will tell you how to do it. HWOB was trying to help you out; he told you where to get the info. On the Park Tool website, top-right corner of the page is a link to Repair Help. There will be a picture of a bicycle that you can highlight parts on. Click on the FRONT hub and it will show you several options of hubs.
Hope this helps,
matt
Posted on Sep 17, 2009
  • 21 Answers
SOURCE: I cant figure out how to put the front tire back on the bike
I assume you are referring to the brake cable. If so, there is a brake lever on each side of the wheel. The driveside lever (the left side as you stand in front of the bike) has a small hinged part with slot cut at one end. On the brake cable itself, there is a curved metal housing thru which the stranded cable runs and then is attached to the brake lever with a pinch bolt. You place this curved metal piece (called the noodle) in the hinged, slotted piece. Then the tension on the cable keeps it all together. You might want to look at sheldonbrown.com for a picture.
Posted on May 20, 2010
dunnbiker
  • 8546 Answers
SOURCE: i bought a mongoose dxr
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
Or it could be the dreaded mismatch of new chain with worn drivetrain parts...
http://sheldonbrown.com/chains.html
Posted on Apr 15, 2011
I took the chain off to repair and now I can not figure on to put back on. Around the two small gears. please help
Hi Jeremiah:
Try this:
- Hang the chain over the axle sprocket
- Pull the two small gears towards the front of the bike
- put the chain to the front of the highest gear, and
- around the rear of the lower gear
- then it goes to the pedal end.
Hope this helps.
Jan 31, 2016 | Next 26" Avalon, Comfort Bike, Full...
What is the problem? (required)
The best thing find some similar bike and see where this part goes.
It is hard to explain in writing how to install it.
Mar 13, 2013 | Cycling
Do I have to buy new bikes to get higher range of gears?
Actually no! you can visit your bike shop and ask them for higher range. What they do is change the front wheel ring in order to give you higher range.
Jan 17, 2013 | Cycling
Can't figure out how to get the rear derailler back on after tube change.
Hi Eric Rivera...
Check out the following webpage and I think it will answer your questions on the derailler.
Please take time to rate me
Bud
http://www.youtube.com/watch?v=1KHpyuwIvxE&feature=related
Oct 17, 2012 | Mongoose 24" XR-75 Girls Bike
Comfort 050 technology attachment catches the rear wheel spokes and causes the chain to come off the spokes.
Matthew, The item giving you trouble is the rear derailler. It works by moving the chain in (closer to the spokes) and out (further away from the spokes) so that the chain can climb onto the next larger or smaller gear. Yours is apparently going too far in when you try to shift to the largest gear. There are a pair of adjusting screws that limit how far in and out the derailler will go. Use this link to find some great repair help. Just click on the derailer on the bike in the picture. Good luck.
Aug 27, 2012 | Cycling
Just bought a Novara Randonee. I have had problems with shifting. A couple of times the chain has locked up when shifting the front derailler. Tonight, the back derailler started shifting on its own as I...
There could be multiple causes for the front derailleur problem, which I assume means that the chain gets jammed between the derailleur and chainwheels. It is not possible to tell you what it is over the Internet, especially as it could be a combination of factors. You can start to look into it by attempting
Front Derailleur Adjustment. Detach the shift cable and make sure it moves smoothly back and forth as you move the shift lever. If not then the cable needs lubrication or replacement first. How To Replace Road Bike Gear Cable . Once the cable is OK proceed with derailleur positioning and adjustment from start to finish, skipping no steps. If you are not confident following the steps, or the problem continues, you need to get help at a bike co-op or shop.
The rear derailleur problem is most likely due to a sticking shift cable, such that you moved the shift lever but the cable did not move as many gears, until it later slipped to the correct gear. Follow the brake cable procedure above to see if that helps.
p.s. The problem of course has nothing to do with the bike brand/model.
Jan 19, 2018 | Novara Randonee
CHAIN REPLACEMENT
May 05, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
143 people viewed this question
Top Jeep Cycling Experts
Michial Gueffroy
Bill Boyd
Donald Ayers-Marsh
Are you a Jeep Cycling Expert? Answer questions, earn points and help others
