Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Jenn-air ww30430p The clock/oven display is dark and displays nothing when I put in info.. Can still turn the ovens on with the switch membrane but cannot turn it off. Have to flip the breaker to shut the oven down each time I use it. Regards, Randy Wood
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
This can be the light unit or the power unit supplying the voltage to the light unit. both cost about$150 each. I need a wiring diagram or know the voltage that comes out of the epower supply
Posted on Dec 01, 2007
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
Wall ovens
This Usually indicates a shorted keypad. Turn off at the breaker. Unplug membrane strip connected to the clock from the clock, turn breaker on. If code comes back replace the clock, if no code you need the touchpad replaced
Let me know how this goes, thanks
May 11, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
The oven is randomly beeping and the display is reading f7
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic oven control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Apr 10, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air wall oven won't cancel / shut off . Recently replaced membrane.
Hey - the ribbon link from membrane to control is a tricky plug to get in right- double check this connection and let me know if it helps- Thanks- Ed
May 13, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
The electrical panel does not light up
I'm afraid you are going to need a new display board. Not very hard to change but a pricey item. Have seen this problem a few times. Good Luck!
Oct 05, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
196 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
