Question about Home
I need model number of aqua glass acrylic shower, i have the serial number, can it tell me model number?
  • 2,963 Answers
Try MFG website, or their customer service email or
for an Owner's manual try manualslib.com
Posted on Apr 10, 2015
Is glass or acrylic better for a saltwater aquarium?
There is no definite winner here. It is truly a matter of choice. I think the main argument against acrylic isthat it scratches easily. It also is much lighter than glass so will therefore requirea much lighter stand. However, it isimportant to note that glass is heavier so it tends to support more. Essentially, it comes down to the ofyour tank. If you have a small tank, Isuggest acrylic. If you have a largetank, I suggest you get glass.
May 14, 2012 | Fish
RE: Everest-Jennings Shower Wheelchair, Serial Number G-101711. The fabric back is worn out and I need a replacement. Can you please tell me where I can order one?
The parts for the E and J shower chair are distributed by Graham Field Health Products. Call customer service at 800-347-5678 to get a replacement. Provide them with the model and serial number and they should be able to help.
Mar 19, 2011 | Health & Beauty
I have a Maax Tigress shower. This will be 3rd time I've taken shower door frame off base to recaulk. I have leaks where frame meets base. I don't think base is stiff enough, because I can feel it flex...
If the GE Silicone was used first then this may be the cause. For some reason the GE formulation does not adhere very well to new plastic/acrylic, however it does very well on most other surfaces. The mono brand is better for plastics/acrylic. If all of the GE silicone was not removed before the mono was applied then the mono formulation would not stick very well to the GE silicone that was not entirely removed. Unfortunately there is no easy way to do this other than with a plastic scraper tool and lots of elbow grease. Rubbing alchohol can be used to soften the silicone slightly and will not damage the acrylic, aluminum or glass. If the mono was applied first then the flexing will be the problem. The only solution to a flexing problem is to remove the shower unit and reinstall the unit in either a morter or sand base to provide more support for the shower unit. If you use a morter base ensure there is a vapour barrier installed between the morter and the shower unit as the chemicals/minerals in the morter will degrade the shower base over time. The downside to morter is that it will not flex and may cause cracking over time if and when the house shifts. A sand base will shift with the house.
Aug 21, 2010 | Maax Home
Soap scum on shower doors
We definitely want to stay away from any cleaning products that have an abrasive. Your local grocery or department store will have products specifically for cleaning soap scum. Some products will work better than others depending on the type of mineral content in your water. The best product is one where you don't have to do an excessive amount of scrubbing to remove the hard water and soap scum stains. Be sure to follow the manufacturers instructions for the best results. Again depending on the mineral content of your water you may have to try a few different products until you find one that works the way you want it to. There are also products you can purchase that you would spray onto the glass after a shower to prohibit the buildup of soap scum.
Jul 24, 2010 | RTO Shower Enclosure, 6mm" Tempered Glass,...
Crescent rod installation into a acrylic walled shower/tub unit. instructions say differant hardware needed but not included,consult contractor or hardware store for installation.
You will need to seal any holes made in your acrylic walls inside your bath unit. When installing the brackets to the wall, try using a piece of rubber (pre-cut for a custom look) between the acrylic wall and the bracket mounting hardware. Be sure to seal everything with a clear latex caulk that is designed to resist mold.
May 08, 2010 | Crescent Rod The Rod - 5' Curved Shower...
Broken rollers on shower door
The rollers for most shower doors are a stamdard size and are available at most hardware stores. The Bigbox stores might even carry rollers for you specific make and model.
Feb 25, 2010 | Aqua Brass Prestige Shower Kit #2 AQUA...
How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
Apr 04, 2009 | Home
Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
Dec 28, 2008 | Grohe 24'' Relexa Shower Bar with Swivel...
Home Logo
212 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
