Question about Oreck Vacuums
Have a brand new oreck magnesium ... Why would the vacumn on about the 2 nd or 3rd sweep come up off carpet and floors as if it is popping a wheelie?
  • Oreck Master
  • 2,992 Answers
Brand new? Warranty should still be in effect. I'd persue that route.
Posted on Apr 10, 2015
  • 97 Answers
SOURCE: my oreck practicly sticks to the floor.
Replace your belt by removing the screws from the baseplate, removing the baseplate and brushroll, and hooking the belt around the silver metal motor pulley. Then put the belt on the pulley side of the brushroll, and pull the brushroll back into its home in the front nozzle, ensuring that the brushroll ends are oriented the same direction. Spin it to ensure that everything spins freely, and then replace the baseplate. Party.
-R
Posted on Mar 08, 2009
  • 206 Answers
SOURCE: My Oreck has in the last 2 weeks become very hard
Look at 3 things:
(1) is there something wrapped around the rear
wheels or axles?
(2) Is there something wrapped around the small, front wheels or axles. (not likely this is the culprit.)
(3) Is your brushroll still turning. (This requires looking underneath while unit is on, have someone else nearby to pull the cord from wall, turn on & off quickly and make sure brush roll spins.
If it is rear wheels, you can pop them out if necessary to clean the debris, they may be hard to press back in. Similar for the small front wheels, don't loose the axles. If brush roll is issue, check belt, insure that brush roll will spin freely and does not have debris wrapped around it.
Posted on Aug 12, 2009
  • 197 Answers
SOURCE: My Eureka Boss Widetrack leaves debris behind
check for blockages in the brush bar compartment and hoses
Posted on Sep 28, 2009
  • 377 Answers
SOURCE: Oreck xl commercial spits out dust on bare floor
It might be that the beater brush is spinning when you tip it up to look at it but slight pressure of it contacting the floor is enough to stop it. If it were my machine I would remove the beater brush and clean it as best I could, paying particular attention to the end pieces on the brush that hold it in place. A little WD40 between the end pieces and some twisting to be sure it worked in well. I would then reassemble with a new belt being sure it is on correctly so it turns the brush in the proper direction.
That is about the least expensive thing(s) you can do at this point before going further. I have one more potential cause, but it is best to check these first.
Please let me know how you make out.
Posted on Oct 06, 2010
SOURCE: broken techdrive
Your Transmission fork has becime disconnected. You need to pull the transmission and make sure that it is installed correctly, Check the following and pay attention to picture number 17. I had the exact same problem which occurred because I dropped the Kirby hard after lugging it down the stairs, it is a very easy fix and I am a banker, not a repair guy. Good Luck! http://www.goodvac.com/kb_results.asp?ID=16
Posted on Dec 25, 2011
Worked well until purchased new thick carpet,now can't push it.cleaned &changed all filters. cleaned brush. tried removing rubber string gasket. no help .
Barry,
Most vacuum cleaners will not roll well on real thick carpets. There are only a couple of vacuums out there that will work on thick carpet. The Oreck Magnesium models and most of the Miele vacuums will work on thick carpet and some manufacturers of carpet will tell you to use one of those two brands. Hope this helps!
Jul 08, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Is there a Dyson vacuum that Will work on high pile Mohawk carpet?
Patty,
I am not sure about any of the Dyson vacuums being able to handle that carpet. I work at an Oreck store on the weekends and I know that we have had several customers come in with the same question as yours and we recommend the Oreck Magnesium RS or any of the Miele vacuum cleaners. They have been tried out on Mohawk carpet and have been found to work well. Hope this helps!
Apr 16, 2015 | Dyson Vacuums
Why is my Oreck platinum pilot hard to push on the carpet?
is there a carpet setting on it versis hard wood floors
Mar 08, 2015 | Oreck Vacuums
How to more easily vacum plush carpet with oreck XL vacum
The only Oreck vacuum cleaners that are rated for plush carpets are the two Magnesium models.
Jun 25, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck magnesium won't turn on
Could be that you need a new battery in the handle. It takes a 2032 button type battery.
Apr 20, 2014 | Oreck Magnesium Upright Vacuum
How do you replace the mico-sweep blade that is broke
Most of the time, you cannot get a new one of those blades unless you replace the entire base plate. Depends on the model that you have. I would suggest checking with a local vacuum repair shop to see if they can help you. If you go to Oreck's website Oreck Store Locator you can see if you have one near you.
Mar 25, 2014 | Oreck Micro-Sweep Blade 7500901
My Oreck XL 2455 vacuum will not go forward when switched on, it sticks.
That piece helps to keep debris directed into the brushroll housing on bare or very thin carpet floors. On medium and thick carpet its not going to really impact performance.
Oct 19, 2017 | Vacuums
My Oreck has become very hard to push across carpet
IF IT PUSHED EASILY ON THE SAME CARPET BEFORE, THEN THE BRUSHROLL IS NO LONGER CONTACTING THE CARPET IT USED TO. A NEW BRUSHROLL AND/ OR BELT SHOULD GET YOU MOVING AGAIN. TRY THE BELT FIRST, MUCH CHEAPER.
IF YOU HAVE RECENTLY CHANGED THE BELT BY REMOVING THE BASEPLATE (NOT THE RECOMMENDED WAY) CHECK BASEPLATE TO MAKE SURE IT IS FLUSH WITH HOUSING.
Jun 28, 2009 | Oreck XL Deluxe U3700 Bagged Upright...
Oreck XL21
What does the belt tension feel like? Is it possible that the new belt you fitted is a bit too long (and starts to slip as soon as it encounters any real resistance). Any more methodical diagnosis is going to depend on observing which bits of the machine are still moving, and which aren't when the brush roll is stuck. Gather this information with caution, as it's a good way to lose a couple of fingertips. A.
May 17, 2007 | Oreck XL21 Bagged Upright Vacuum
Vacuums Logo
126 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
