Question about Westinghouse Refrigerators
Westinghouse 522 fridge slow motor kick in resulting in tripping out circuit breaker
    Top Expert:
  • Westinghouse Master
  • 10,875 Answers
You need a bigger curcuit breaker or a better fridge
Posted on Apr 10, 2015
Westinghouse RPG423GR fridge is freezing and tripping circuit is this the thermostat? Is a wiring diagram available?
The compressor windings shorting out are usually what trips the breaker. Someone will need to test the windings and if they are defective it will be best to replace the fridge
APPLIANCE 911
Jan 10, 2016 | Westinghouse Refrigerators
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
Fridge is causing the circuit breaker to trip when plugged in
Hi!!
Your unit is shorted out, check power cord and wiring on lower back of unit.
It may be the compressor shorted out.
If you have a pet, they some times remove wire insulation.
Turn unit so you can see the compressor housing on the bottom of the unit's back, you may need to emove the cover. turn breaker on and check if the small fan and the compressor kicked in. If the compressor did not start, and the breaker tripped again call a service tech to check unit.
Good Luck!!!
Aug 12, 2010 | Westinghouse Refrigerators
New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Jul 10, 2010 | GE Refrigerators
My fridge trips the breaker when you try to turn it on
I have a couple of things for you to check or rule out. Today, a refrigerator is required by electrical code to be connected to a dedicated, 15 amp outlet because the newer fridges are more efficient and use less than 12 amps. Not long ago, a dedicated 20 amp outlet was required because the older fridges were rated to use 12 amps or more (but less than 16 amps) and needed the larger size circuit. A 20 amp circuit breaker or fuse should not open for any standard residential fridge under normal operating conditions. A 15 amp circuit breaker or fuse _MAY_ open if an older fridge (needs 12 amps of more) is connected. Make sure that if a circuit is opening at the fuse or breaker, it is not because there are several appliances or devices in use and on the same circuit as the fridge.
The same holds true for "ground fault" and "arc fault" type circuits. If an older fridge is connected to such a circuit - nuisance tripping may result. Most newer fridges however shouldn't cause a problem on these circuits. Ground fault circuits have a "test" button on the circuit breaker or, "test" and "reset" buttons on an outlet providing this protection. Arc fault circuit protection is available only in circuit breakers (as of this time - but may become available as outlets some time in the future).
If you need to to try to isolate the problem on a 20 amp circuit, disconnect all other appliances on the other 20 amp circuits in the kitchen and dining room, then see if the fridge stays running. Alternatively, you could use a heavy duty extension cord to connect the fridge to a known isolated 20 amp circuit to see if the fridge runs. This is meant only to troubleshoot - the fridge should not be left connected via extension cord for normal operation.
If you still have tripping, you might need to have the fridge professionally serviced, as a ground fault could be a dangerous condition left unchecked.
Please rate this replay id found to be helpful - good luck!
Jul 07, 2010 | Frigidaire Refrigerators
Westinghouse Silhouette Frige 522 frost free is
UNPLUGGED FOR 24 HOURS AND LET IT TOTALLY DEFROST.
Apr 24, 2010 | Refrigerators
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
67 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
