Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
