Why won't it run after it gets wormed up - Computers & Internet
  • 2,963 Answers
Battery condition? Power supply? Too hot? Fan not keeping it cool enough?
Posted on Apr 10, 2015
Electric window won't roll down
It's not a worm gear,just a small gear on the motor and a long
metal gear an the regulator. They are riveted in,if the door panel
cracked or a rivet came loose the gears may have slipped,have to
pull the door panel to see.
Mar 19, 2013 | 1998 Ford F150 Regular Cab
CAR RUNS THEN WONT EXCLERATE AFTER IT GETS WORMED UP SPITS AND SPUTTERS.
Have you had the fuel pressure checked ?
Is the check engine light on ?
Dec 11, 2012 | 2002 Chrysler Sebring
Why won't my sprinkler turn. The water comes out fine, but it won't rotate. Mine is a plastic model, and I can't figure out how to get inside.
1) Use a 5/16 nut driver (or flat screwdriver) and remove 5 screws holding body to motor assembly.
2) Use pliers to hold the worm bearing assembly where the tee screws in. Hold worm bearing and remove tee.
3) Use a 3/8 inch allen wrench to remove the worm bearing assembly. The allen wrench is placed in the same hole where the tee was located. (Removing the worm bearing assembly allows you to separate the upper motor housing from the lower housing.)
Use care when removing the top and bottom halves as sometimes the small flat washers tends to fall off the shaft when you open sections.
When screwing worm bearing assembly into the lower motor housing, you are screwing brass into plastic. If over tightened, the housing will split. Rule of thumb: tighten until it feels snug then go a 1/4 of a turn.
May 21, 2012 | Nelson Sprinkler: Traveling Tractor
Won't run
Your MAP (manifold absolute pressure) the hose either pop out or is broken or the sensor harness is disconnected
Mar 28, 2012 | Chevrolet 1500 Cars & Trucks
Screen locked up, turned computer off, turned computer back on, fans running, monitor won't come back on, and keyboard won't respond
Hi hay783...
Sounds like you may have a virus/trojan/worm/etc...
To remove a virus,trojan,worm,etc from your computer...do it the EASY way...let someone else do it for you.
Start your computer, as the computer is starting keep tapping the F8 Key.
This will start the computer in the Safe Mode.
Once in the safe mode go to the following webage below and download,install, and run Microsoft Safety Scanner for FREE.
Once you run the Microsoft Safety Scanner (it may take quite a while depending on the size of your hard drive) it will remove all the virus's,trojans,worms,etc it finds, if it does not completely remove them all you will be given a chance to chat with a Microsoft Professional thru a pop open window and he will take control of your computer (with your permission) and finish removing all the rest of the virus's, trojans, or worms that are on your computer for FREE!! Can't beat FREE!!
Please take time to rate me
Sep 05, 2011 | HP Pavilion a620n (PC028A) PC Desktop
My powermatic table saw is very hard to raise and lower the blade and i have removed the knob that tightens the handle so the blade does not move and its still very difficult to move the blade
You need to do some maintenance on your saw. First unplug it. Then blow out the sawdust from inside the saw, especially around the trunnion ways and gears and worm gears that engage them to raise/lower and tilt the saw. Use a good quality lubricant to lube these worm gears and the shafts and pivot points. I use motor oil, have for years, and find it does a better job and lasts longer than any kind of grease or silicone. Use an oil can with a long spout so you can direct the oil where needed, then move the saw up/down or right/left to work the oil into the worm gear and mechanism. In a pinch WD40 is fine, though it won't last as long. Periodic re oiling will maintain the mechanism in peak condition, and the drops of oil you spill in the process won't do any damage to your so. No, it won't get gummed up with sawdust. Try it, you'll like it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 08, 2011 | Powermatic Saws
How can i remove virus worm/autoit permanently
its simple guys..!!!
if it asks for permission to access outlook..don't permit it because it is a smart virus and is going to spread it to all the people on your contact list...!!!
simply open task manager and end process tree of KHATRA.exe , gHost.exe , xplorer.exe and OUTLOOK.exe seperately...!!
then run your anti virus or download one if you don't have one..!!!
run a complete computer scan in detail..!!
then delete all files which are infected by the virus because the results contain only duplicate files which are created by the virus
Feb 04, 2008 | Acer TravelMate 2300 Notebook
MFC-240c
Remove all the software. Run the worm cleaner software again Restart the computer Ensure you are off line and the Anitvirus program is disabled. Reinstall the software and follow the instruction exactly. Worms don't eat printers
Sep 03, 2007 | Brother Multi-Function Center MFC-240C...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
