Question about iLive IC600B Intelli set clock radio with am/fm radio and ipod dock
Dispaly is very dim but will dim all the way out with button.
What can I do to make the display Brighter???
Screen dims on dark scenes
Melissa check you TV's picture settings, cinema, sports, movie, store, etc.and try a different display setting.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 03, 2016 | Televison & Video
How do you make the number that tell time light up darker so you can read it.
If you want to make the display brighter (remember, it auto dims in low light):
1. Hold down the "clock set" button while pressing the "volume" button up or down (up for brighter, down for dimmer).
Jun 10, 2014 | Bose Wave Radio
Adjust display brightness on frigidaire PLMV168
Good Afternoon Friend,
I understand that the display on your Frigidaire microwave, model# PLMV168, is dim and you are wondering if there is a way to make it brighter. There is not a way to make the display on your microwave brighter. That is the particular design of your appliance. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire PLMV168 Microwave Oven
Led display is too dim
There is a large button on the top of unit press it and it will make it brighter.
Apr 15, 2014 | Sony Speaker Dock for iPod and iPhone...
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
I have a CDA 7892 alpine works great but would like the display to be brighter seems a bit dim manual does not say this model can be adjusted or am i missing it any help thanks in advance
You didn't specify if you wanted the display brighter in the daytime while headlights are off or if it is too dim when the headlights are on, with respect to the rest of the instrument panel illumination. Too bright is easier to deal with but too dim is tough. If it is always too dim under but daytime and night time conditions the only way to improve brightness would be to very gently disassemble the front panel (easier if it is the removable type) and determine what provides the back lighting. If there are tiny LEDS you could painstakingly add more LEDS or swap them out for brighter LEDS. There could be a lot of guesswork determining if this or that LED was brighter than what is in the unit as built. It may just be easier to live with it as-is.
Mar 26, 2011 | Alpine CDA-7892 CD Player
CANT SEE THE SCREEN DISPLAY IN THE DAY TIME,ONLY AT NIGHT
press and hold the dim button it should get brighter !
you have it set to dim
Apr 19, 2010 | 12-Band Radar/Laser Detector
Dim Display
go into settings and change your contrast it may help the display
Sep 12, 2008 | Garmin Edge 305 GPS Receiver
Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
iLive IC600B Intelli set clock radio with am/fm radio and ipod dock Logo
56 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
