Question about Measuring Tools & Sensors
Model no.00822A2 yes and no the number is 00822A2
Model 00822A2. Why doesn't inside unit show outside temperature?
If you tried removing and replacing batteries, you should bear in mind that all batteries should be removed to "reset" the station then batteries should be installed in the outside sender first and time allowed for it to begin transmitting temperature. Next, batteries should be installed in the receiver and you should begin to read outside temperature.
Nov 24, 2015 | Acu-Rite Measuring Tools & Sensors
How much
Hi jaygomez_13,
Please check this, You can also click this link: http://www.acer.com.ph/ac/en/PH/content/series/aspire to check the price, specifications, models and other details. aspire_11_350x250.jpg Aspire AS4745G-352G32Mnks ( LX.PSM0C.037 ) 28000 PHP
Linpus™ Linux® - Intel Core i3-350M (3MB Cache, 2.26GHz) - 2GB DDR3 RAM - 320GB SATA HDD - ATI Mobility Radeon HD 5470 with up to 3579MB of HyperMemory - Screen Size 14" HD 1366 x 768 resolution - Battery 6-cell Lithium Ion (Li-Ion) 4400mAh - Up to 6hours battery life
AS4745G-352G32Mnks LX.PSM0C.037 aspire_11_350x250.jpg Compare energy_star.jpg Intel® Core™ i3 Processor
  • Operating System Operating System Linpus™ Linux®
  • Processor & Chipset Processor Manufacturer Intel Processor Type Core i3 Processor Model i3-350M Processor Speed 2.26 GHz Processor Core Dual-core Cache 3 MB 64-bit Processing Yes Hyper-Threading Yes Chipset Manufacturer Intel Chipset Model HM55 Express
  • Memory Standard Memory 2 GB Maximum Memory 8 GB Memory Technology DDR3 SDRAM Memory Standard DDR3-1066/PC3-8500 Number of Total Memory Slots 2 Memory Card Reader Yes Memory Card Support Memory Stick PRO
    xD-Picture Card
    Secure Digital (SD) Card
    MultiMediaCard (MMC)
    Memory Stick
  • Storage Hard Drive Capacity 320 GB Hard Drive Interface Serial ATA Hard Drive RPM 5400 Optical Drive Type DVD-Writer Optical Media Support DVD-RAM/±R/±RW
  • Display & Graphics Screen Size 35.6 cm (14") Display Screen Type Active Matrix TFT Colour LCD Display Screen Technology CineCrystal Aspect Ratio 16:9 Screen Mode WXGA Backlight Technology LED HDCP Support Yes Graphics Controller Manufacturer ATI Graphics Controller Model Mobility Radeon HD 5470 Graphics Memory Capacity 512 MB Graphics Memory Technology DDR3 SDRAM Graphics Memory Accessibility Dedicated TV Card No
  • Network & Communication Wi-Fi Yes Wi-Fi Standard IEEE 802.11b/g/n Ethernet Technology Gigabit Ethernet Bluetooth Yes Bluetooth Standard Bluetooth 2.1
  • Built-in Devices Webcam Yes Microphone Yes Finger Print Reader No
  • Interfaces/Ports HDMI Yes Total Number of USB Ports 4 Number of USB 2.0 Ports 4 VGA Yes Network (RJ-45) Yes
  • Software Operating System Linpus™ Linux®
  • Input Devices Keyboard Yes Pointing Device Type TouchPad
  • Battery Information Number of Cells 6-cell Battery Chemistry Lithium Ion (Li-Ion) Battery Capacity 4400 mAh Maximum Battery Run Time 5 Hour
  • Power Description Maximum Power Supply Wattage 90 W
  • Physical Characteristics Colour Black Height 29 mm Width 342 mm Depth 245 mm Weight (Approximate) 2.20 kg
  • Miscellaneous Package Contents
  • Aspire AS4745G-352G32Mnks Notebook
  • Lithium Ion Battery
  • AC Adapter
  • Security Features
  • Kensington Lock Slot
  • BIOS Passwords :
    • User
    • Administrator
    • Hard Drive
    Green Compliance Yes Green Compliance Certificate/Authority Energy Star
  • Warranty One-year International Travellers Warranty (ITW)
    Hope it helps.
    Thank You for using Fixya.
Sep 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Does every tv have their own serial number?
Yes they do. The model number is the one that remains the same with identical tv's
Jul 28, 2011 | Panasonic Televison & Video
Is this tv model number HD-compatible?
that tv has 3-inputs digital comb filter
component video input
tv,vcr,and dvd
and also a S video input which can be connected to hp for video transfer.
yes it is compatible.
Apr 07, 2009 | JVC AV-36D303 36" TV
Is this the right number for my dryer?
Yes the Model Number on most all sears Kenmore products have a 3 didget code a dot then the rest of the model number. The first 3 numbers denote the manufacturer.
Mar 13, 2009 | Kenmore Dryers
I am looking for parts for model nushuatec 6123cp, please advise on were to buy from and also i was looking for service manual from which i can get correct part numbers
First Off I would really appreciate you GETING the Model Number Right, the Correct Model Number is CP 6123, and second off this was made by RICOH
and it is a DUPICATOR, so yes I can help you get parts and yes I do have the DVD service Manual for it it is $ 49.95
Mar 03, 2009 | Office Equipment & Supplies
Plastic piece that holds water hose to spray into drum is broken. Can I buy a new one
yes they are available. you just need to provide the model number to the parts supplier.
Jul 16, 2008 | Washing Machines
Can i connect a stereo receiver to my 62 inch projection tv
Depends on your model # - I will need that to provide you an extra assistance:
If your model is....
62PL9524 - YES
62PL9774 - YES
if it is any other model, I will need model number to tell you for sure
On these two models, you would hook r and w audio from the mono out port to the stereo receiver
May 29, 2008 | Philips Televison & Video
Measuring Tools & Sensors Logo
100 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
