How do you dub cassette to cassette - Audio Players & Recorders
  • Audio Player... Master
  • 1,267 Answers
You can use a dual cassette but their transports 90% of the time are junk. Transfer of a tape degrades the signal ever copy so you want to use a deck of high quality to do the duplication. I have done this many times and had 21 cassette decks hooked together at once- I was a Technician at Teac so I got a lot of decks cheaper. The copies can be good if you use the right equipment. Usually the line out of the source deck goes into the Line in of the recording deck. The levels can be adjusted on the output of the play deck or the input of the record deck. It is not that hard to do.
Posted on Apr 12, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Posted on Apr 09, 2015
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Inconsistent dubbing
Over time cassette equipment has oxidation buildup on the heads and on the transport mechanism. I use rubbing alcohol and cotton swabs to clean the heads and all rollers. I make sure there is no leftover fuzz from the cotton swabs.
Jun 05, 2014 | Telex Copyette Series Ii - Original
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Can i dub from a cassette to a cd on my panasonic sxbs?
No you can not go from the cassette to cd on the unit. You can go from cd to cassette though. The unit is not a cd recorder.
Apr 20, 2010 | Panasonic RXD27 Radio/Cassette/CD Boombox
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Aug 15, 2008 | Sony TC-WE305 Single Cassette Deck
Dule cassette dubbing
No sir,
you can not dub a tape on single cassette deck, unless you have another cassette deck.
ramesh22
Jun 09, 2008 | Sony TC-WE475 Single Cassette Deck
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Teac w 600 r tape deck
PUSH DUB BUTTON HIGH SPEED OR NORMAL
Aug 14, 2007 | Teac W-600R Single Cassette Deck
315 people viewed this question
 Grubhead
Grubhead
