Question about Retail Supplies
I just bought a sw100, but i can't do anything cause i don't have the password. How i can reset it to factory default.
  • 592 Answers
Wow good luck
Posted on May 09, 2015
Don't the user name or password for my motorola SB900 can you help ?
That's depends...First, do you have the password to log into the modem? it seems that the default is admin/motorola. If that hasn't been changed, you could log in and remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
May 30, 2012 | Computers & Internet
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Need security password for setting up wireless
That depends on the model, but I have included a link that you should be able to figure out.
http://www.default-password.info/d-link/
If your router is somehow set to anything other than default, and you don't remember the password; then just hit the reset switch on the back for 5-15 seconds. You could also unplug the router for thirty seconds or so, then plug back in. Then you router will be set just like it was made from the factory.
~may the source-code guide you my friend~
~Lee-nuxor~
Aug 31, 2011 | D-Link Computers & Internet
I need to reset this so i can lock it i suppose?
If there has been a password already set that you don't know you will need to reset to factory defaults. If there isn't one look here: http://portforward.com/default_username_password/Belkin.htm and find your router and try the default username and password. If you do end up resetting to factory defaults then look at the link above and use the default username and password to get into your router.
May 18, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Default factory pass fails while cannot be reset
There should be a reset button on the back of the router. Once you locate it press it in and hold it down for a few minutes to reset the router to factory default. Then try logging into it.
Nov 22, 2009 | D-Link DVG-G1402S Wireless Router...
I BOUGHT MY IPOD AT A PON SHOP AND IT WAS LOCKED?
Try reseting to factory default
http://support.apple.com/kb/HT1339
Mar 24, 2009 | Apple iPod MA446LL/A MP3 Player
Printer Password
If you reset the network card on the 8008 back to factory defaults it will reset the web password back to 'sysadm'
To reset factory defaults power the pritner on holding down CLEAR, keep CLEAR held down whilst you power the printer ON, keep the clear button held down untill you see RESETT on the display.
Resetting factory defaults will reset all network settings EXCEPT - IP, Sub net and Gateway address
May 13, 2008 | TallyGenicom 8008 Laser Printer
Factory default
The following reset procedure will completely restore the default settings on the VDI-604 and VDI-624. Note: If you do not remember your password, you will have to reset the router to factory defaults. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Note: After resetting the router to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Factory default
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Retail Supplies Logo
76 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
