Question about 1991 F700
Blower Motor works on high speed only - 1991 F700
    Top Expert:
  • Ford Master
  • 49,967 Answers
Check replace blower resistors or climate control module.
Posted on Apr 10, 2015
    Habit-Forming:
    Scholar:
  • 170 Answers
I would place a good bet on the Control Module- I haven't come across a blower working without the resistor / since no resistor means no power, no power means no blower, but your system is blowing but not on all selected channels.
Posted on Jan 17, 2016
    Genius:
  • Ford Master
  • 1,028 Answers
Replace blower motor resistor.
What is an AC diode fuse? I have a 2006 AWD Pontiac Torrent the AC/Heat doesn't work, I've changed all fuses for the HAVAC and still no AC/Heat blowing out of vents. What could be the problem?
Could be a number of thing's ! Testing the electrical circuit is the way to find out what's wrong . Using a wiring diagram and a DVOM - digital volt ohm meter . Videos on youtube showing how to test it ! Without testing i would only be guessing . Does it work in high speed ? In high speed it by-passes the resistor . If it doesn't work in any speed more then likely the blower motor is the problem !
Air Speed
The HVAC control assembly applies ground to the blower motor control circuit that corresponds to the selected blower speed. The resistors and the blower motor are in a series circuit. The following list represents the number of resistors in series with the blower motor per particular speed request:
• Low speed--3 resistors
• Medium 1 speed--2 resistors
• Medium 2 speed--1 resistor
When the operator requests High speed, the HVAC control assembly applies ground directly to the blower motor through the high blower motor control circuit. The resistor card has a fusible link which, if blown, will require that the card be replaced.
Blower Motor and Resistor Diagnostics by Wells
Jun 11, 2017 | Pontiac Cars & Trucks
98 buick heater stop working
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Dec 14, 2012 | 1998 Buick LeSabre
Sorry its blower
These will help.
Thanks.
Dec 07, 2012 | 2006 Kia Sportage
Heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
Nov 28, 2012 | 1988 Honda Accord 4 Door
My blower only will go on high and now its not working? but now its not working whats wrong i have no defrost or anything
Usually if your blower motor will work on high but not any of the other speeds then the blower motor speed resistor is at most likely fault. If the blower will no longer work at all you still may have a bad speed resistor but may also have a bad or corroded connector at the speed resistor or blower motor control switch, or even a blower motor that has finally failed. A blower motor that is pulling too many amps can damage the speed resistor, connector, and switch so I often also replace the blower motor whenever I find any of these other problems. Hope this helps and good luck!
Mar 29, 2011 | 1998 Plymouth Breeze
2005 jeep AC and heater blower only high speed works
check fuses, then wiggle speed control while moving, may need new dash control for lower speed, usually high speed works through relay may be the reason high speed works
Nov 03, 2010 | 2005 Jeep Grand Cherokee
I only get the fan to work on high speed, the lower speeds do not work
Hi!!
The Blower Motor Resistor also called Manual Temp. Control resistor), is fried, replace. The price with floor console $25 and without floor console $65. here is a pic.
the resistor is located on the blower motor housing, fastened by two screws. It is the part where the electrical plug connects, the plug on the pic. goes to the blower motor.
A HELPFUL - 4 THUMBS rating for this solution would be greatly appreciated. Thank you for using FixYa.
Oct 19, 2010 | GMC Yukon Denali Cars & Trucks
Blower motor wont work
Disconnect connector at blower under pass side of dash.Check for power & ground with the blower switch in the #4 speed (High).Most Likely a blower motor if all 4 speeds are out.If high works but no other speeds,you need a blower resistor.Blower easy to change 3 screws & one connector.hope this helps
May 19, 2009 | 1993 Saturn SL2
1991 F700 Logo
98 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
