Question about Samsung SCX 4521F All-In-One Laser Printer
I have the same printer, it says that its havin an Open heat error and it's not operating showing the same error every time I start it.
  • Anonymous Dec 01, 2008
    Wehn I start the printer it say open heat error
  • ianhard Dec 07, 2008
    I keep getting this oopen heat error message, how can I fix this?
  • 1,113 Answers
Needs fuser, non user replacable but it is the hot bit at back whare paper turns around and exits.
Part required (U.S.) link below, fit at own risk, best taking to agent.
also see link below for more info different model same problem.
Posted on Nov 14, 2007
Open heat error
Posted on Sep 21, 2010
wanted to thank "guest" above for the excellent 16 steps! I had the same issue, followed the steps just to find out that my heat sensor (the "probably silicon rubber" part in #7) melted actually on the drum (henec the burnt smell I had together with the "heat" message). So, new parts for me entirely, but at least I did not have to pay anyone to discover the melt and do not need to pay anyone to fix it back, so thank you very much "guest", it was very helpful to me! thanks for spending the time to write all that, it is hard ot see this dedication these days on the internet!
Posted on Nov 12, 2008
Fix for open heat error - worked on Samsung scx 4500 printer
The problem may be caused by dirt getting in between the fuser cylinder and heat sensor. Before ordering a new fuser -which can be expensive - and if you have some experience with electronics, you may try the following:
1)Disconnect the power supply from the mains and the printer cable and wait for the printer to cool. Do not just turn the printer off; unplug it.
2) Open the printer. Remove the printing cartridge.
3) Locate the two Phillips screws that hold the fuser cover (the one that has high temperature and/or high voltage warnings printed on it) and remove them with a suitable tool.
4) In the middle of the fuser unit on the interior side there is a heat sensor. It has two wires, that go to a connector on the left of the interior side (with the printer open towards you). The connector sits in a holder. Pull it out of the holder, then disconnect the male from the female. Untangle the sensor's wires from the plastic wings that hold them onto the unit.
5) Now you are ready to remove the heat sensor. It is held in place by one Phillips screw similar to the two you removed from the fuser cover.
6) Having removed the screw, pull the sensor first slightly away from the fuser (to clear the plastic margin on the fuser unit) and then straight up. DO NOT apply force! it should come out very easily.
7) Now you are holding the heat sensor. You are looking at a black square piece of plastic with a hole in the middle (for the screw) out of which on one side come out the two wires ending with a connector, and on the other side, two thin plates laminated together in a soft transparent plastic material (probably silicone rubber). If you look carefully, inbetween the two metal plates sits a very tiny component - the actual semiconductor sensor.
8) On the side of the sensor that when in operation faces the hot fuser cylinder, you will find a layer of solid black residue. Now comes the tricky part: removing the residue. Careless manipulation of the sensor may result in a permanently damaged sensor. You have been warned.
9) Hold the sensor (or place it on an adequate surface, eg rubber) so that no excessive mechanical tension is applied to its active parts (the laminated plates and semiconductor). Scrape the residue off the sensor gently with an object that will not harm the transparent plastic lamination. Do not use anything sharp. The residue should come off very easily. If it doesn't, do not apply excessive force.
10) You are ready to mount the sensor back on the fuser unit. Insert it exactly as you removed it, with the active part down. The wires that go to the connector should come out the side opposite to the connector (if you took notice when you disassembled, they make a u-turn when assembled). You will not be able to mount the sensor if you insert it the other way around.
11) Secure the sensor with its Phillips screw. Do not apply excessive torque.
12) Thread the sensor's wiring through the plastic wings on the fuser body and assemble the connector.
13) Put the cover back on the fuser unit and secure it with its 2 screws.
14) Put the printing cartridge back in place.
15) Close the printer. Connect it to the mains and to the computer. Turn power on.
16) Happy printing.
Posted on Oct 21, 2008
My samsung scx 4100 series printer showing open heat error.....what can i do for this error
this is a fuser problem. Maybe lamp is broken or heat sensor didnt work properly.
You can fix it whit repalcing fuser module or replacing broken parts (cheaper way).
Just visit authorized service - my advice!
May 25, 2010 | Samsung SCX-4100 All-In-One Laser Printer
On 2/1 and then again on 2/3 we have received an error message " Open Heat Error". At that time the printer would not function. Upon shutting down, and turning back on the message was removed...but this is...
Any heat errors on the dell 1815 means the fuser has gone bad. Your best bet is to replace the fuser, part # UG297. Here is a video that shows you how to replace it. has these in stock and ships same day (till 7pm est). Hope this helps, Good luck!
Feb 03, 2010 | Dell 1815dn All-In-One Laser Printer
Getting open heat error message, what's the solution
hi i dont know why my printer is showing open heat error i dont understand please solve this problem
Jul 10, 2009 | Dell 1600n All-In-One Laser Printer
Diaplay shows open heat error after one print.
The fuser is overheating. Probably now has blown the overheat thermostat. You have to replace the fuser to get rid of it. Not real hard to do.
Mar 28, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Sharp cash register XE A202
finally solved this problem...yeah
first press CL
then ESC then ESC
then 1 (grey button)
then CLK#
after this step your screen will show - 01 -
now your register is ready to go..
good luck.
Jul 08, 2008 | Computers & Internet
Replace the fuser, it's not reaching operating temperature within a set time (normally a thermister or the lamp is shot)
May 21, 2008 | Samsung ML-3561ND Laser Printer
Open heat error
when i on my scx-4216 samsung laser printer it show on screen open heat error on display screen
tell me the solution
Apr 17, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
Sep 19, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
1,142 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
