Question about Apple iPhone Smartphone
How do I fix my oculus rift?
The rotation is now opposite, when I turn left it goes right, it's so dizzy.
  •  Tarn Alcock
    Tarn Alcock Apr 14, 2015
    Which OS are you using? Is this happening in a specific game or all the time?
    New Friend:
    Problem Solver:
  • 6 Answers
I also love to play virtual reality game with my VR devices. Initially, I have the same problem with my Oculus Touch controller. I have fixed my Oculus Touch problem by watching its review, Let's play, and Oculus controller tutorial on Snow dragon website.
It is one of the best sites which provides latest Virtual reality news. You can also fix your Oculus controller on this website.
How do I fix my oculus rift? - oculus-touch-2-k0idpvudbkigj40naah0oup3-1-0.jpg
Posted on Dec 15, 2017
    New Friend:
  • 4 Answers
Does the impeller on a Yamaha 200 outboard on a left hand motor spin the opposite way as a right hand motor
No, the gears in the lower unit are cut to rotate in the "other" direction... If the impeller were to rotate opposite - it would mean the engine had to run backwards... and that does not happen.
Mar 19, 2017 | Yamaha Boating
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
I need a wallplate with the duplex on the left and toggle (for garbage disposal) on the right. I can only find the opposite configuration. Does this combination exist somewhere?
Rotate the plate 180 degrees so top is now the bottom, and bottom is top..
Then duplex will be on opposite side of switch.
I think that will fix the problem. Add a comment.
Gene
Aug 05, 2013 | Cooper Industries Cooper Wiring 2158V 3...
My steering wheel sits to left and the car also pulls left, but when i hold the steering wheel straight the car pulls to the right. I took the car to quick-fit and the charged me for a load of stuff that...
swap the tire from left to right if the opposite happens then you have a tire pull this is known as a radial pull and the fix is either you rotate front to rear or a new set of tires
Aug 29, 2011 | Mitsubishi Lancer Cars & Trucks
Is the crankshaft pulley bolt left or right thread to undo diesel P38 engine
the bolt will turn opposite direction of your engines rotation. so if when setting the timing your manual tells you to crank your engine clockwise then you will need to rotate the bolt clockwise to remove it. you will need a huge belt wrench or a reverse socket in order to keep the engine and pulley from moving so you can crack the bolt. if the transmission is not attached to the engine at this point you may be able to use a crowbar to prevent the flywheel from turning and stop engine rotation that way. goodluck
Mar 27, 2011 | BMW 525 Cars & Trucks
How do I align the steering after I replace the steering gear box so I have equal rotations on the steering wheel from left to right on a 1992 chevy astro van?
with the front of the vehicle raised in the air (with jack stands underneath), turn your steering wheel lock to lock, counting how many times the steering wheel does one complete rotation..........halve this number and rotate the steering wheel the opposite way...this will be the approximate middle of the steering rack movement
One important ppoint to note that not all items are built exactly, so you will require a wheel alignment after any change in steering or suspension components to be sure that everything is running true and correct
Aug 02, 2010 | Chevrolet Astro Cars & Trucks
Screen orientation is portrait rather than landscape the mouse is also opposite for example up is right down is left left is up and right is down ...(?) help please!!!!
depending on your system video card there are functions on the key board that can rotate the Screen, try CTRL+shift hold this bottons down they press the arrow keys untill your screen goes back to normal
or if the ctrl+shift does not work right click on your desktop click graphic properties or graphic options there should be an option for you LCD monitor to rotate your screen back to normal by selecting the option 0 make sure you click apply or OK after changing the settigns to make it take effect before closing the options screen.
Jun 15, 2010 | ASUS Eee PC 900 PC Notebook
Ignition wiring got mixed...????
COOL! -
I'll sort it out for ya!
The engine has the spark plugs
O O O O
1 2 3 4
0 and the dizzy has contacts 0 0 <- my pic of dizzy contacts 0
I'm no artist but this looks like a golf engine and dizzy drawing to me.....
Anyhow the dizzy looks like this 1- 0 the 4 contacts... 2- 0 3- 0 4- 0
Number 1 plug is furthest left of the engine.
Number 1 plug on the dizzy is the "top" contact furthest back of the car Number 2 on diz\zy is the LEFT most contact Number 3 on dizzy is the Right most contact Number 4 in dizzy is the Bottom (nearest front of the car) contact NUMBERED!!!
Hope this helps -
Leave feedback good or bad.
Jan 21, 2010 | 1985 Volkswagen Golf
WHICH WAY DO THREADS ON MAINSHAFT RUN
If the right side is a right-hand thread, the left side is opposite that -- left hand thread.
Charlie
Sep 13, 2009 | Grinders
Apple iPhone Smartphone Logo
91 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
