Question about Food Mixers
..beaters won't stay attached.
  • 2,992 Answers
Owner's manual trouble shooting. Usually takes a little finesse to get them to go in far enough to catch.
Posted on Apr 10, 2015
Can I get parts hot kitchen aid hand mixer model khm7twh beater won’t stay in because plastic tabs are broken that hold the beater in
Hello, Joe -
From a post on a YouTube video demonstrating a McGyver-type fix to a damaged beater ring (the plastic piece which holds a beater in place) apparently KitchenAid has discontinued the availability of the beather ring.
This is the link to the YouTube video with the McGyver-type repair demonstrated:
https://www.youtube.com/watch?v=CmS4FbROS50
The comment about the discontinued beater ring is from Dan Peters.
See the information here from KitchenAid:
http://producthelp.kitchenaid.com/Countertop_Appliances/Hand_Mixers/Hand_Mixer_Assembly_and_Operation/Beaters_fall_out
If you decide not to try the McGyver-type repair and choose to purchase a new hand mixer, you may wish to put the old mixer up for sale, to be used for repair parts (since it still has 1 good beater ring.) Or, you can send the old mixer to electronics recycling.
Best wishes.
Feb 27, 2018 | Food Mixers
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
Dec 21, 2014 | Oster Food Mixers
Beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and don't fit
They need to be replaced or the locking mechanism does, but in the meantime, wind some thread around the beater end and this may keep them in temporarily.
Mixer won't turn on after adjusting beater height
The kitchenaid warranty is exactly 365 days from date of registration "No Questions Asked" on day 366 you have no warranty and you gotta pay.
Now the good news; first check the wall socket, I know it works but check it anyway. then check your plug, did you step on it while you were working on the machine? The plug often falls to the floor during work and can get underfoot, you may have broken the plug it'self. next you will need a parts list for your model from Kitchenaid's website.
http://www.kitchenaid.com/customer-service/manuals/
My first suggestion is to try a minor adjustment of the speed control switch, they often get out of sync when you do something to the machine. You can find several videos of this on the youtube site. "Adjusting the speed control switch on kitchenaid mixer"
If the two or one of the top 2 screws on the speed control switch move it can shut the machine down just like an on/off switch. Did you remove the back cover during your adjustments? Did you remove and replace the carbon brushes on the side of the machine while working on the machine? If you did you might have put them back in incorrectly, if you did they will also act a a shutoff switch. If you did not take them out then DON"T as there are four ways to put the brushes back in and only one way is correct and there are two brushes to deal with. Has work ever been performed on the mixer before? Because if all you did was to adjjust the beater height screw then nothing should have effected the normal operation of the mixer. So if there is anything that you did but did not include in your description of work you performed then please let us know. We strive to give accurate solutions but... as I am a KA tech I do not have any other solutions with out the machine in front of me. Just so you know you can fix this yourself.
May 26, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Need replacement beaters for Rival 12 speed stand mixer. I am unable to find any 89-attachments for this mixer as I have misplaced the beaters that came with the unit. I've looked everywhere. Are...
I cant find any information online at all about buying attachments for my new Rival 12 Speed Blender!! Does anyone know how I would find out how I could go about ordering new parts for it?
Jul 01, 2011 | Rival Food Mixers
How to attach a icecream maker KICA0WH to KitchenAid Artisan Series KSM156 that has a cap on the beater shaft. In the manual it shows how to attach it to the mixer with spring and no spring but does not...
After the bowl has been frozen you attach it to the base. Then you take the part your asking about and attach it where you would put a beater or whip. The trick is to make it spin and the notched part stay in the "center of the circle". You don't use the top front of the mixer. I had to practice without the bowl and beater bar to make sure I had it right.
Jan 04, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
I cannot get the beater to lock in place. The
Hi VBPROSANDY, When you say beater, I assume you mean your flat beater. Are you having the same problem with your Wire Whip beater and dough hook? If you are not, then the first thing I’d do is look inside the flat beater’s attachment well, to see that there is nothing; i.e. hardened food, dough or batter, in the bottom of it that would prevent the agitator shaft and groove pin from seating properly. The flat beater has two drain holes at the bottom for drainage, but if these get plugged it may prevent accumulated ‘gunk’ at the bottom from escaping, and over time the buildup may prevent the beater from seating properly.
If you find the beater attachment well is clean, then from the KA Instruction manual, to attach the flat beater...
1. Slide speed control to OFF and unplug.
2. Slip flat beater on beater shaft.
3. Turn beater to left, hooking beater over the pin on shaft.
Finally, check the groove pin on the agitator shaft to make sure it hasn’t become bent so that it doesn’t fit the beater properly. Pins shouldn’t bend, but sometimes they do.
The beater attachment process should not require any effort as the agitator shaft should easily fit into the beater’s attachment well and easily turn to the left. Your planetary should not move during this process and if it does move it will take some effort on your part to turn it. The fact that you’re turning the planetary means you’ve turned the beater as far to the left as it should go to ‘lock’ it. When you get this far, let go and the beater should fall into place on the groove pin.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 06, 2009 | KitchenAid KP2671 Professional 6 Series...
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Nov 12, 2006 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
138 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
