How do I fix the misfid in the paper tray two?
How do I fix the misfid in the paper tray two in ricoh 3035 copier?I have already cleaned the ROLLERS, but the problem still exists. many thanks
  • 3 more comments
  • Bebboo Bebo
    Bebboo Bebo Apr 12, 2015
    Misunderstanding,
  • Bebboo Bebo
    I have ricoh 3035 copier not as a printer
  • Bebboo Bebo
    many thanks to all
  • Bebboo Bebo
    I think there is a stuck, how to solve?
  • Bebboo Bebo
    Bebboo Bebo Apr 15, 2015
    plz help
Soulvisitor
  • 1113 Answers
SOURCE: Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Posted on Oct 26, 2007
adonscott
  • 106 Answers
SOURCE: Photo Paper Feed
hi,
the issue that you have might need to change some settings from the printing properties. WHen you hit on PRINT, a box will open, right? look on the top right of that box, you will see "PROPERTIES" or "Preferences" just click on it, then another box will open. Click on Printing Shortcuts tab, try to review the settings. And if you want to print using the main tray, it should set it to Automatic select or Main tray. And make sure that it sets to General Printing. But if youre going to print a photo, you will have options there to choose what type of paper when you click on that, the settings on the paper size, paper source, etc. will change also. For paper source, make sure that it sets to Photo Tray.
If you will be able to open printing preferences, all options are there, you just need to read and choose which settings you want to use.
Thank you so much.
adonscott
Posted on Jul 07, 2008
  • 300 Answers
SOURCE: Printer will not grab paper
You may need to obtain the HP Paper Feed Cleaning Kit from Customer Service by contacting them here. While your speaking with them you may want to ask about any issue that have came up with your particular model because I have read they have replaced some models that were even out of warranty.
To use:
It seems that by what Im reading, this is mostly caused by a dried out roller (especially if they are grey so you also may have some other options:
NOTE: These options may void warranty.
  • You may try applying a thin layer of vaseline on the rollers that pull paper. You can usually access these rollers from a door at the back of your printer. This should also soften the rubber. I would suggest running a sheet of plain paper through a couple times to clean off any excess.
  • You can try the Rubber Rejuvenator listed here.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 19, 2008
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
vaadk3@netvision.net.il
hope fore replay.... :)
Posted on Jun 20, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
I have moved my ricoh mpc3500. Now the paper will not go into the finishing unit. can you tell me what to look for?
Try to disconnect all the paper trays, clean the rollers that pick up paper and reassemble the unit
Nov 27, 2014 | Ricoh MPC3500
Have a PE error code, can't find anything in the service manual. I am a Ricoh Technician.
That is a Paper Empty message.
Check the paper cassett home switch and sensors for the tray stack.etc. Then clean or replace the rollers.
Apr 26, 2011 | Ricoh FT3713 Copier
Keep getting misfed paper message. can't see paper
Check the paper tray. The part at the end of the paper might not be keeping the paper pushed to the front of the tray. Remove the tray and check the rollers that feeds the paper. They might be slick. Clean them with some WD-40 sprayed on a rag.
Nov 22, 2009 | Ricoh CL4000DN Laser Printer
How do you fix the scewing on a aflico ricoh 1018 fax/copier machine
Check to see that media is correctly loaded in trays and that all width guides are correctly set (not skewed).
Make sure that the paper trays are correctly fitted.
If you have a bulk paper hopper than make sure all the paper is neatly stacked and fitted properly against the walls and guides of the hopper.
Try turning over the stack of paper in the tray. If you are using letterhead paper, try printing from a different tray.
Do not use previously printed paper or torn, worn, or irregular paper.
Make sure that the paper is not damp or creased.
Check the media specifications. If it is outside of the recommended specifications, problems may occur.
Make sure that the paper path does not have any small piecesof paper or labels stuck in it. Also if you have used any labels, look for signs of gum or glue inthe paper path.
The entire printer path may be dirty and needs the path and rollers cleaning and vacuuming. Printers and copiers both suffer from an accumulation of paper dust and need regular cleaning.
Sep 17, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Misfeed when attempting to make a copy - Ricoh FT5535
If you are a technical person you may want to remove the tray from the machine (pull all the way out, tilt upwards, and pull.) to clean the rollers. Once the trays are removed you will see a set of three rollers for each tray. They can be removed and cleaned or cleaned directly on the machine. They may have build up dust on them preventing feed. Reinstall the trays the same way they came out but in reverse steps.
Then:
1. Pull offending tray all the way out and remove paper.
2. Unlock the side guides and make sure they move freely
3. Set about 100 sheets of NEW paper for now and adjust the side guides and the end fence. The end fence must be against the paper (touching) and the side guides must NOT be too tight agains the paper as this will prevent the tray from lifting.
4. Make sure the paper size dial is set to the paper SIZE and ORIENTATION.
5. Close tray and test.
Let us know what happens. In the worst case it could be a Magnetic clutch malfunction
Aug 28, 2009 | Ricoh Office Equipment & Supplies
False ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Paper jam E light won't reset in Ricoh A423
hi im jules_09,look for thr microswitch or sensor in the tray try cleaning it with alcohol just soak with alcohol if that doesnt work replace the sensor or microswitch
Dec 10, 2007 | Ricoh Aficio 450 Copier
k24674
jasbo
jasbo
