Question about Tristar Jack LaLannes Power Juicer Express - Black
How to fix a juicer that hums but does not turn?
Serial # 03578010
  • 2,039 Answers
Someting prevent the motor from turning some debrie or a bearing is jam
Posted on Apr 09, 2015
My juicemon juicer won't turn on, and I'm not sure how to fix it
Make sure all parts are properly assembled AND tight. Hold power cord up and down at base of juicer when turning on, this will tell you if you have a short in your wire. If yes, replace the wire.
Feb 05, 2014 | Juicers
Base motor
The Start capacitor in the motor is faulty or the centrifugal switch is worn out info@nutrifaster.com.au
Jul 13, 2013 | Nutrifaster Ruby 2000 Juicer
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
http://www.omegajuicers.com/juicers/masticating-juicers.html
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
Motor is humming not working .. stoped in between juicer
it is jammed, or it is too full....stop, take apart, scoop out pulp, put back together and restart. go slow when juicing...too fast will jam it!
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
Doesnt turn on
unit must be fully assembled, then add fruit and press down with plunger
Jul 17, 2010 | Jack Lalanne Power Juicer 250 Watts
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
Acme Juicer Supreme Juicerator 6001
BEARINGS MIGHT BE GONE. OLD JUICER
AND SOME PARTS ARE NOT AVLB. OR
HARD TO GET. THEN AGAIN IT MIGHT BE
SOMETHING SIMPLE. MINE IS FROM 1990
AND I DO MY OWN REPAIR. NOT WORTH IT
TO PAY FOR IT.
Mar 21, 2008 | Acme 5001 Supreme Juicerator Juice...
Tristar Jack LaLannes Power Juicer Express - Black Logo
754 people viewed this question
Top Tristar Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Tristar Kitchen Appliances - Other Expert? Answer questions, earn points and help others
