Question about Coleman Heating & Cooling
Coleman evcon eg17a a/c unit cools but will not shut off once desired temp is reached how do i fix problem
    Master:
    Sergeant:
  • 388 Answers
Make sure your thermostat is set up correctly. Check out
How to Set the Thermostat FAN AUTO ON or OFF Switch function var po... just to make sure. If it is then try resetting the a/c. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If it is still giving trouble then id suggest you contact an Air Conditioning Repair Service.
Posted on Apr 12, 2015
Coleman Evcon DGAT070BDD furnace fan continues to cycle on & off after temp is reached blowing cold air. Replaced control board & limit switch - problem continues
If its turn on AND off, I'd suspect a shorted control wire. Remove the G terminal at the control board and see if the problem continues. If it does not, then you know it's in the wire that connects your unit to the tstat, or the tstat itself. The reconnect G, and at your tstat, disconnect G. If the problem goes away, with G disconnected at tstat, its the tstat. If it continues, the the control wire has a short between G and R. If neither one of these work, then there's something else in that unit that's causing 24v power to engage G. Hope this helps!
Mar 09, 2017 | Coleman Heating & Cooling
Our coleman evcon furnace has started clicking over & over again before it starts up, we replaced the thermostat & the same thing happens.We are afraid that this is hard on the furnace & have resorted to...
Suspect that the igniter is causing the clicking (or could be a relay). Suggest having the furnace serviced. There is also a major recall for some models of the Coleman Evcon furnaces.
Oct 29, 2013 | Heating & Cooling
Coleman eb15b blower fan will not shut off
The most common issue with this symptom and unit is a stuck blower relay.
Once the unit is reached temp and the heat elements stop the blower is to shut down when unit cooled. In your case the switchis stuck resulting in continuous fan.
Here is a manual that is real handy for troubleshooting electric funaces.
http://www.nordyne.com/Literature/359a.pdf
Mar 18, 2010 | Coleman Propane Forced Air Heater...
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
OK, here's the problem - Samsung model RB1955SH - plug refrig in it cools both frig and freezer to desired settings - however, once system reaches stttings and turns off compressor, will not restart system...
the temp controller is bad in the fridge once it reaches cooling temp desired it cause the temp comtroller to go into a shut off mode due to being weak on the temp sensor tube
Jan 18, 2010 | Refrigerators
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Coleman evcon dgat090bdd. New ignitor won't heat up.
Looks like 4 flashes might be high limit fault on this furnace. (I don't have a manual for this furnace, just searched online for the code meaning) Is the unit running flame at all? Is the unit running flame for a while then shutting flame off before desired temp is reached? Does the main air fan turn on to circulate air through your diffusers? Does it feel like the unit has much air flow out of the diffusers if the fan is running? Is your air filter clean? If it is infact your high limit switch, it is usually caused by not having enough airflow through the furnace and overheating occurs.
Hope this helped, let me know if I can assist you further :)
Jan 16, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
80 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
