Question about Sport & Outdoor - Others
Blade replacement How do I do this
  • Wylie Johnson Apr 09, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Novelist:
    Champion:
  • 210 Answers
It would help immensely if you could include the name of the item that needs a new blade.
Posted on Apr 10, 2015
Band saw blade twists while trying to cut a straight line
The replacement blade could be defective.
Jul 30, 2016 | Blade Saws
5-h-push mower has bad veberation blade is on tight
bent blade, bent crankshaft, blade not balanced are all possible causes for vibration.
If you sharpened the blade recently try rebalancing it.
You could have struck something while mowing and bent the blade or bent the crankshaft on the engine.
If blade is bent replace it. If out of balance, rebalance it.
If crankshaft is bent replace it, have it straightened or replace the engine.
To replace or straighten the crankshaft it will require engine tear down which requires knowledge and tools for small engines.
Apr 22, 2016 | Garden
How replace blade on 7 1/4 circular saw - Milwaukee
UNPLUG THE SAW first!! Look for the blade lock on the top or front of the motor body, Hold the lock button down while turning the blade nut with a wrench. After a bit you'll feel the lock button engage and hold the blade firm. Rotate the the wrench counter clockwise and remove the nut, Slide the blade out from under the guard and replace with a new one. Reinstall the nut following the above procedure.
Sep 15, 2014 | Milwaukee Tool Saws
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
Replacing 2004 gmc envoy xuv rear wiper blade
Replace the blade and the blade holder. These days everything but the arm gets changed....and gone are the days of just replacing the rubber...
Jul 19, 2011 | 2004 GMC Envoy
Can a 7 1/4" circular saw blade be used to replace
Some furniture shops used 7 1/4 circular saw blade for other brands of circular saw. Based on my experienced it's applicable as long their is clearance for the blade not touch the adjustable safety cover of the unit. Thanks for asking FixYa.
Jun 14, 2011 | Porter Cable Plywood Circular Saw Blade
Table saw king
Does the blade go to the right if you place the fence on the opposite side of the blade? If so, then the teeth on one side of the blade are dull. The dull teeth beat into the wood, and the sharp teeth cut when the blade is deflected by the dull teeth, leading the cut further and further from the straight line of cutting. This happens when something dulls the blade, like a nail, a foreign object embedded in the wood like stone, or if you use the wrong blade for the work being done, i.e. using a crosscut blade for consistent rip sawing.
First, get a spare blade or two for the saw, don't depend only on one blade. Use a combination blade to get the best balance from ripping and crosscutting. Then for the dull blade: If it is a steel blade, replace it with a carbide blade - a few dollars more, but well worth the upgrade. If it is a carbide blade, get it sharpened, as they will also get dull, though you can't always see it. If it is a carbide blade, and teeth are broken on it, ask your sawyer (saw sharpener) to determine if it is worth replacing the teeth, or if it is less expensive to replace the blade.
A quality blade will last longer than the least expensive ones, as the materials are better machined, balanced, and finished. Hope this helps.
Jan 23, 2010 | Saws
How to remove and replace the wiper blades on an 06 Murano
Me again. After looking at the blade for 15 minutes or so I did the following. Remove the wiper blade from vehicle (makes it easier to work on). There is a little tab under the blade near the end of the wiper blade arm. Press it and slide/pull the wiper blade toward you. Now when you look at the wiper it seems like its a sealed unit. Check the ends and you will see the rubber is flexibe enough to allow you to slid the "wiper" out ot the blade. You can get the replacement refill (the wiper) or a replacement wiper blade (the whole unit) from the Nissan dealer. Take the refill and slide into the blade assembly. Take your time. You might have to straighten the blade a little so that the refile lines up with the holding tabs in the blade. Looks impossible, but once you've done it you'll be surprised how simple it was to do......****
Dec 21, 2009 | 2006 Nissan Murano
Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Apr 22, 2009 | Oster 76076-010 Hair Trimmer
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
