Question about Plumbing
Faucet turns when going from cold to hot i tightened nut underneath but it evntually loosens up
  • Wylie Johnson Apr 09, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Novelist:
    Champion:
  • 210 Answers
You will have to either take the nut off the shaft and apply some thread adhesive that will grip the nut when you run it back up tight or get a nut with a nylon insert and the proper thread, If you can get the nut off to take to a store that sells small hardware, they should have both, the nut and the thread adhesive.
Posted on Apr 10, 2015
The cold tap handle off position has moved
Is this a widespread lav faucet? If it is, the mounting nut underneath has ,loosened. Use the faucet hdle to reposition it correctly, and have someone hold it in place while you tighten it. You will need a basin wrench.
Nov 25, 2016 | Plumbing
Kitchen faucet
You will need a basen wrench ( a special wrench to tighten nuts that secure faucet to sink) and open end wrenches. First shut off both hot and cold water valves. Using open end wrench, disconnect hoses from valves. Now, you must loosen both nuts (under the sink towards back wall) Using the basen wrench. After removing nuts, lift faucet up
Jan 09, 2014 | Plumbing
How do I stop a dripping faucet shower faucet. Both hot water and cold water knobs are typing but it still Dripps
Turn your water off at the main line. remove both faucet stems, take them to Lowes or Home Depot and get a repair kit. Follow the ininstruction and replace the stems and turn your back on.
Dec 07, 2012 | Washing Machines
Delta 476 faucet is leaking. I purchased the proper parts - RP4993 seats and springs and RP25 O-Rings for single handle faucet. Do we need any specific tools? Would you please be very...
http://www.faucetdirect.com/mediabase/specifications/476install_051710.pdf
Here is where to find the manual for your faucet. The only tools you should need are a pair of slip-joint pliars for the main ring and the hex key tool that came with the replacement parts. Remove the handle by loosening the hex screw on the underside. Make sure to turn off the water before you go any further and you will need to turn off both hot and cold.
Remove the dome-shaped cover either by hand or with some pliars.
Pull out the ball with the stem in it and underneath there will be two rubber washers with two springs underneath. Remove the washers and springs and put the new ones in. Put in the new stem (ball with stem) taking care to line up the slot in the side with the nub inside the base. Replace the round washer on top with the triangle hole in it and put the dome shaped cover back on.
Before turning the water on, use the back side of the hex-key tool to tighten the nylon ring that screws down into the dome shaped cover. Put the handle back on and try the faucet, if it moves too hard, loosen the nylon screw a bit, if too loose then tighten it. Once it "feels right" you can reattach the handle and turn the water back on.
I suggest turning on the water slowly and look for leaks. Not as difficult as it sounds.
Feb 24, 2011 | Delta Faucet Plumbing
The base keeps coming boose. i keep tightening and
If you just need to keep the nut from coming loose, try LocTite Blue (assuming metal thread and nut). You should be able to buy it at the local hardware store.
I had the same problem with a slightly different Price Pfister model sink. My problem was primarily because the sink basin was thin and not "beefy" enough to support the faucet. The whole thing would flex because the metal was thin and the nut would come loose.
Using wood for reinforcement down there is a bad idea (it would get wet and rot). So, plastic was the way to go.
I bought an inexpensive piece of plexiglass/lexan at the local home improvement store. A cheap plastic cutting board would work well too.
I cut a rectangle that was a couple inches wider than the the faucet holes and that would fit underneath the sink basin where the holes for the faucet were.
I marked the holes and cut them with a hole saw (Go slow, the heat from the hole saw will melt the plexi!). Cutting slightly oversize makes everything fit easier.
I put my new "reinforcing washer" in place and tightened everything down. The nut snugs up nicely against the plastic and after four months: no more flex, no more nut loosening.
Jun 13, 2010 | Price Pfister Marielle Kitchen Faucet with...
Tighten chain?
Depending on the model, you adjust the chain tension using the screw that is located either between or below the two nuts that hold the sprocket/bar/chain cover. Loosen the nuts and turn the screw clockwise to tighten, counter-clockwise to loosen. Once you have the tension set, lift up on the bar from underneath and tighten the two nuts. Proper tension should show about half of the chain drive, and should only be done when cold. After 4 to 5 minutes of run time, stop the saw and check the tension again. A little heat in the bar/chain will cause it to loosen up. It will need re-adjusting.
May 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a single handle Moen kitchenfaucet. I
You turned the faucet body when you tightened faucet you need to loosen and reposition body so handle goes left and right equally and retighten while making sure faucet body does not move
Nov 12, 2009 | Moen Plumbing
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Plumbing Logo
126 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
