Question about Dishwashers
Water is setting at the bottom of the dishwasher after cycle. Is it clogged
    Top Expert:
  • Dishwashers Master
  • 45,340 Answers
Could be plugged up
Posted on Apr 09, 2015
  • 641 Answers
SOURCE: Dishwasher not spraying
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
Posted on Sep 13, 2007
  • 121 Answers
SOURCE: water build up in dishwasher- clogged drain
I would not recomment putting chemicals in the dishwasher. There is usually some kind of filter in the bottomt at you can easily take out and clean. It's common to have parts of labels and plastic clog this up.
Try removing and cleaning this first. It may also be reached from a separate hatch in the fronc of your dishwasher, depending on the make and model. Just make sure it's securly back in place before you start it afterwards, or you may flood your kitchen.
You may also try to disconnect the hose and blow through it to see if you may be able to blow back any objects stuck there.
If none of this helps your problem may be in the pump, and then it's usually a job for professionals.
Posted on Nov 07, 2007
aborcass
  • 2651 Answers
SOURCE: dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Posted on Feb 22, 2008
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
SOURCE: Dishwasher--water in bottom -end of cycle.
You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. once drained put it through another cycle. this should reset the drainage level. hope this works as it has for ours, bye
Posted on May 23, 2008
When the cycle finishes, there is water in the bottom of the dishwasher this begins to smell
there is some kind of clog in the drain system. clean the screen in the dishwasher, there gets a build up of food, or misc stuff in there. it is probably draining, but slowly.
the dishwasher usually has a pump that pumps the water out with force, but if clogged it will be slowed down and when the cycle stops there will be water left in bottom
hope this helps
rick
Jul 15, 2011 | Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Bottom fills with water, line not clogged
This means that the outlet valve or the drain motor is faulty or their is a leak in the pipe between them and the machine.
Sep 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Water does not drain from GE dishwasher.
Remove the drain hose from under the sink to verify that there is no clog. If the dishwasher runs in the "cleaning" cycle, but won't drain, you either have a clog or a bad solenoid. All the solenoid does is opens a little door to change from cleaning cycle to drain cycle. This part is VERY EASY to change. Definitely a project for DIY. The part runs around $60 from a parts place. Check ebay if you do not need it immediately and you can save abt $30.
Aug 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Water left in bottom of dishwasher after cleaning
I suggest checking the drain and screen. There is most likely a little clog in there. If there is even the slightest amount of clog, the washer will not finish the drain cycle.
May 23, 2009 | Dishwashers
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
although hose is not clogged is it installed correctly?is there what they call a high loop installed under sink( loop up high as possible under sink to prevent both water siphoning out or returng back to machine after cycle complete. when you press the cancel button do you hear the water flowing freely into sink drain, if not sounds like you got somthin in hose or pump assy
Feb 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Drainage problem
cycle switch on the front is most likely bad
Jan 09, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
