Question about Kenmore Sewing Machines
I cannot wind the bobbin on my old Sears Kenmore 1802 Sewing machine. Help!
  • Kenmore Master
  • 12,535 Answers
Until you can get your sewing machine fixed so that you can wind bobbins, you can purchase a stand-alone bobbin winder at the local fabric store (last time I checked, they were ~$25). They are helpful to have anyway as using the stand-along unit to wind bobbins saves wear-n-tear on your machine.
Posted on Apr 11, 2015
    Top Expert:
  • Kenmore Master
  • 52,149 Answers
Put bobbin place and loosen the hand wheel .on the right end of machine
Posted on Apr 09, 2015
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: can't get the clutch to disengage so that I can wind the bobbin
Where is the model number on Kenmore machines?
Posted on Dec 20, 2008
  • 3 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Posted on Nov 05, 2010
SOURCE: BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Posted on Dec 08, 2010
SOURCE: how to wind bobbin on sears 38516231301 sewing machine
check with sears to see if they have a manual
or email these sites about a manual
sewvacdoctor.com
a1sewingmachines.com
sewusa.com
Posted on May 29, 2012
Testimonial: "Thank you so much Debbi"
Digital display shows bobbin wind. Bobbin wind spindle moves slightly. When depress foot pedal, stitches for only a minute- stops. Cannot select any stitches as menu display remains on bobbin wind.
try putting a bobbin on to wind and then take off again, make sure when you do that the bobbin holder clicks back into the sewing position not the winding, you might need to give it a little push in the right direction then see if it sews ok for you. if not may need a service call.
Jul 20, 2017 | Sewing Machines
How to fill a bobbin on a Rivera 1681?
fill-bobbin-rivera-1681-d05l30nuhtdrvd3uj4vejdej-1-0.jpg These videos may help. Not the same as your machine, but the way older sewing machines wind bobbins are pretty similar.
1 How to wind bobbin on the Brother XL2600i sewing machine
Loading thread on the bobbin old Kenmore sewing machine
Jan 04, 2016 | Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
I inherided my mothers sewing machine, with no instruction book I can't figure out how to put thread on the bobbin
If, I were you, I would take to Sears, to the sewing machine department and have the salesman show me how to thread it and wind the bobbin. You can order a manual from Sears parts direct, if you don't have it.
Oct 20, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Self winding bobbin
I think you need to push the bobbin winder (with your bobbin on it) towards the handwheel. Press the foot pedal and it should begin winding. If this doesn't solve your problem, post back with more details of what you've done and the kind of problem you are having.
As a last resort, go to Sears and let them show you how to wind a bobbin.
Sewman7
Feb 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
102 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
