Question about GPX PC332B CD Player - Black LCD CD-DA gpxpc332b
Cannot get player to work, says er
It just stopped and when put in new batteries, shows something that looks like a battery and does not work
HAVE LOADED CD, PRESS PLAY BUT GET ONLY A WHIRRING NOISE THEN Er WITH BATTERY ICON ON DISPLAY BUTTON - HOW DO I GET THE CD TO PLAY?
Normally a battery icon on a display indicates that the battery power is too low to operate the device. If the device uses disposable batteries, it's time to replace them with fresh ones. If it uses rechargeable batteries, recharge them. If recharging the batteries fails to work, they may have reached their useful lifetime and need to be replaced as well. If the unit has a internal battery that is chargeable, and charging fails to work, you may need to have the unit serviced to replace the internal battery(ies) or just get a new unit, depending on the cost-effectiveness of repairs.
May 25, 2016 | GPX PC101B Portable Compact CD Player
Phillips jogproof 45 esp stopped turning on
Unless something has happened to it in the last hour then it would seem the problem has something to do with the batteries or connections or the way you fitted them.
Batteries should be fitted with the greatest care as accidentally putting them in wrong can cause terminal damage to the device - in a second!
It isn't unknown for a new battery to be faulty so I suggest you first test the batteries and if ok next check the terminals in the battery holder appear new and shiny and thoroughly clean any that aren't.
Oct 25, 2017 | Audio Players & Recorders
Jensen Personal CD Player Model CD-60 won't play cds. It starts and then shows "ER " message. I've put in fresh batteries - no change. Appreciate your help, thanks so much!
Have you try a Cleaning Disk. Maybe you can use a compress air can (usually sell in pc/electronics stores) and clening up the laser lens. Check for dirty on discs, water drops or scratches. Try another CD
Hope this help.
Regards,
Mar 13, 2011 | Jensen CD-60 Personal CD Player
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
Player won't play
took it back ask for anther one
Nov 16, 2009 | Audio Players & Recorders
T20 low battery and no recharging
this is problem with your hardware.......
Jun 20, 2009 | iRiver T20 MP3 Player
2005 ford expediton 6 disc cd changer
06 expedition 6 cd player and having the same issues,,, Disconnect battery and all 6 cd are stuck inside. "Error cd" shows when pushing eject. Looked everywhere and nothing shows how to fix it. I dont want to buy another radio/cd player for something that ford should know and how to fix?
Nov 14, 2008 | 2005 Ford Expedition
Dvd battery
Hello sara_lou,
I have 2 suggestions for you:
1) Look into purchasing an external rechargeable battery pack for PDVD units (available at Best Buy). It is an external pack that will connect to the players AC port.
2) Prepare for surgery! You will need 6 rechargeable AA batteries, a soldering iron, super glue, and patience.
You'll need to open the battery case and look at the batteries within. Note the direction and polarity of all the batteries and how they are wired/soldered together. You will need to replace all these batteries with the new ones you have purchased. Wire together the new batteries in the exact same order and polarity as the old dead ones. Remove the old ones and replace with the new ones. Solder in where necessary and be sure not to bridge any contacts. Put the case back together with a little super glue on the seam. Replace into the PDVD player when the battery case is dry (or else you may permanently mount the battery case into the player) and set to recharge using the AC pack. if everythign was wired correctly, you should have a charged battery pack in about 1 hour (since most rechargeable batteries come with 3/4 charge in them).
While I don't recomend this second solution, it is plausable for the hobbiest electrician or DIY-er.
Best of luck to you!
Jul 20, 2008 | Insignia IS-PDVD10 Portable DVD Player
Starting displayed won't do anything
Look for a lock or hold switch on the player. Most players have one of these to stop you accidentally switching it on or off when you're not using it.
Let me know how you get on!
Jan 17, 2008 | Delstar DS 31024 MP3 Player
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
GPX PC332B CD Player - Black LCD CD-DA gpxpc332b Logo
316 people viewed this question
Top GPX Electronics - Others Experts
Are you a GPX Electronics - Other Expert? Answer questions, earn points and help others
