Question about Kia 2009 Rio LX
Car won't start
After a few attempts it starts Mechanic has checked the whole car, reckons nothing is wrong apart from the battery in which it was replaced then and there and then after a week or 2 the same problem AGAIN!
  • Kia Master
  • 2,039 Answers
It doesnt turn if your battery was replace 2 weeks ago get the charging system check out you could have a battery drain
Posted on Apr 09, 2015
Car does not start in sometimes and then the whole day no problem
thats tells its not the battery but the starter motor
Jan 18, 2018 | 2005 Chrysler PT Cruiser
2004 Ford Explorer won't start if I let it sit for a a few days. I turn the key and it just clicks but will start with a boost. I have had the battery and starter checked and the mechanic couldn&#
Why didn't the mechanic continue on & resolve the issue?
You don't have the experience to do so, as your here
No one can tell you what is wrong without the vehicle to test,
common sense
Feb 07, 2013 | 2004 Ford Explorer
2002 Ford Taurus, V6 3.0 won't start. Attempted to start, but stop mid start. No clicking, just slience. What else?
Just to the left of the battery is the main fuse junction box and below that under the manifold is the starter with the solenoid on top with the positive cable going to the starter check for a loose connection, and the battery ground sould be right there nearby the starter grounded to the block check it also. You could have a bad cable although it may look okay under the insulator the copper cable may be damaged test with a volt meter while moving the pos and neg cables at both ends.
Oct 28, 2012 | 2002 Ford Taurus
Car won't start unless jumped off. Can the fuseable link on the postive cable prevent the car from starting?
Difficult to say. If you are connecting the jumper cables to the battery posts, the only thing you are doing is boosting the voltage in the battery.
A mechanic would check for voltage at the battery and the starter to check the cables.
Aug 21, 2012 | Cars & Trucks
2001 park avenue won't start or turn over
Hey Gordon,
Remove your battery, take it to O'Reilly's, AutoZone, etc.. have them check the CCA (Cold Cranking Amps)-load test.
.. this is what makes your car crank.>Amperage< ... 12+ volts might run the lights.. but just voltage WILL NOT crank your car.. the age of the battery doesn't matter either..
Sep 20, 2017 | 2001 Buick Park Avenue
Car will not start
try taping on the starter and hve some 1 turn key while you are taping on the starter with a hamer if it starts have the starter replaced
Nov 17, 2009 | 1999 Mitsubishi Diamante
CAR WONT START AFTER SHUTTING IT OFF FOR A FEW MINUTES
The battery has run down flat or the starter has gone bad. check the two.
Good luck.
Rate this.
Jun 10, 2009 | 1995 Buick Riviera
Kia 2009 Rio LX Logo
50 people viewed this question
Top Kia Heating & Cooling Experts
Mike Squire
terry stevens
Andrew Taylor
Andrew Taylor
Are you a Kia Heating and Cooling Expert? Answer questions, earn points and help others
