Question about Westinghouse Televison & Video
Where is the inverter on a 39" Westinghouse LCD TV located? I have removed the back cover but not sure which component is the inverter.
This is model DW39F1Y1. I see the mainboard but not much else after removing back panel.
    Novelist:
  • 242 Answers
It is the little long board mounted on the side of the monitor. you can identify it by tracing the thick pink and white wires from the LCD panel to a little board that looks like it has some tiny coils on it.. you will see some little wires on one side and those pink and white wires on the other. It amplifies the voltage to drive the fluorescent lamps. Usually the lamps are what go bad instead of the board though,, go the other direction and look at the lamp tubes to see if they are black on the end.
Posted on Apr 10, 2015
    Top Expert:
  • Westinghouse Master
  • 74,630 Answers
Are you talking about the back-light inverter? If so, some models of LCD TVS; the back-light inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: OLEVIA 540-B11 42" LCD-Inverter supposedly shot craps
Hi , I had the same problem but a got the power inverter from somebody, here in denver for $260 brand new , if somebody needs this part, contact me and I will send the information , also please write the part number
Sergio
Posted on May 29, 2008
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
I had this problem with these tv`s. The problem actually lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6) replacing these works. On others, the capacitors as well as a few transistors (Q8 - Q1) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
Posted on Jul 20, 2009
SOURCE: I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
Posted on Dec 06, 2009
SOURCE: my tv will not pwr up. grn light flashes then turns red.
I have a Sylvania LD320SS8A and I turn it on and the green light comes on and no picture???? Just black... I can hear some sound but no picture...
Posted on Feb 24, 2010
I have a Westinghouse 40' LCD TV and the back light went out, the TV model is VR-4085DF.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 27, 2017 | Westinghouse Televison & Video
I have a Westinghouse LCD TV, model #CW40T6DW. The TV turns on shows the Westinghouse symbol, channel number and then turns off.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 21, 2016 | Westinghouse Televison & Video
Westinghouse TV picture started flickering, the next day screen went black.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 02, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Westinghouse TV 60" LCD Model VR-6250. Why is the left side of the screen dark?
Back - light (CCFL lamp/s) problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
May 28, 2015 | Westinghouse Televison & Video
My TV.come and have lines on oneside and Dark one the other side
May 03, 2015 | Westinghouse Digital LED LCD TV Remote...
Westinghouse how to
Back-light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
Aug 08, 2014 | Westinghouse LD-3260 32-inch LED LCD TV...
If it takes my LCD Westinghouse TV 20 min. to warm up then the picture is fine, do I need to replace the backlight inverter?
Did you fix the tv Patty? I have the same tv and when i turn it on, it screeches really bad, but after about 20 minutes or so, all is well. I don't think its a main board issue, but i already ordered and replaced the backlight inverter - that didn't solve the problem. I read somewhere that the power supply is what the problem is, but i just don't want to start buying all of these components as my trial and error. I bought a new tv to replace this one but it is no where near my Westinghouse. I love this tv more than my 55" LED Samsung in the family room!
Jan 10, 2012 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My Westinghouse TV has sound but no picture.
Hello Vernacamp, if you are technical you can open the unit, you will most likely need to replace one of the transformers or a capacitor on the power/inverter board. If you are not that technical you can open the back cover and you will need to replace the whole board, if you provide me the TW# located on the back of the TV I can give you the part # you will need to replace along with some websites where you can find the part. Please rate my answer if it was helpful.
Feb 10, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
I have a 37 in. 1080p Westinghouse LCD TV and after a while it makes a popping sound and the tv goes black. The audio seems to be working and when I turn the TV off then back on the problem goes away. This...
Hello, it looks like your inverter boards are going out. If you are atleast a bit technical you can open the units back cover, and get the part numbers for the inverter board, these are the (one or two (master or slave) boards) you can get the part numbers and check out different prices at www.shopjimmy.com, or email Westinghouse parts department for price and availability at parts@wde.com.
Dec 07, 2009 | Westinghouse LTV-37WI 37 in. LCD...
Televison & Video Logo
50 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
