Question about Plumbing
I recently installed a Pfister Cagney Single control kitchen faucet with side spray. The spray has no pressure. The water from the faucet is great. What could be the problem?
  • Wes Vietz Jun 09, 2015
    diverter in faucetnot workn must stuck or has matter in it
  • 69 Answers
Could be trash got into hose( i.e., teflon tape, brass shavings, etc.). I suggest that you turn off water, disconnect the hose and try flushing water through the hose with no sprayer attached. If water goes through, then you have a stoppage in the sprayer. The face of the sprayer usually unscrews allowing you to check if there is trash in it.
Posted on Jun 03, 2015
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 333 Answers
SOURCE: low pressure to the main faucet, great pressure to the side spray
try un-screwing the screen on the end where the water comes out. Could be clogged
Posted on May 01, 2010
  • 25 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
Turning the water off, letting it drain from pipes, then turning it back on can cause debris inside the pipes to loosen and clog your aerator or flow constrictor in the faucet.
Or your new faucet could have an aggressive flow restrictor. You can sometime remove the restrictor or use a drill to increase the size of the hole if its a simple plastic washer.
Posted on May 05, 2012
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
We just installed the Price Pfister Hanover Single Handle faucet in our kitchen. (Series T529). We find that it doesn't have the same pressure as our previous faucet. Is there a reason for this? We have...
Hey,
We have the same problem. Just called Price Pfister with the same question, and she offered to courier replacement parts free of charge. She was much too accomodating. My suspicion is that she gets this question quite regularly. Love to know if anyone has solved this problem as we like the look of the faucet.
Apr 22, 2011 | Price Pfister Hanover Single Handle...
I have a Price Pfister 34 Series Genesis Single-Control Faucet, 3-hole with side sprayer, in my kitchen and it has developed a leak. Specifically, when I lift the lever it leaks from the handle, and when I...
The cartrididge seals have gone bad for what ever reason and the repair is simple enought but I woul take the replacement unless they want to pay for the plumber to come and fix it.
Feb 18, 2011 | Price Pfister 34-3LC Genesis Kitchen...
Low pressure to the main faucet, great pressure to the side spray
May 01, 2010 | Price Pfister Marielle Kitchen Faucet with...
Lack of Water Pressure
If you have the spray head type, I had the same problem...called Grohe. They said to remover the pressure regulator. Take off the spray head, and just inside the end where the water comes in, you will see a white plastice thingy. Remove it. They said you can do it with needle nose pliers, but I had to pry it our with a tiny screwdriver. It came out in pieces, but once out, the water pressure is GREAT!
Mar 07, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Jun 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
211 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
