Question about Ryobi Garden
Spark plug gap for ryobi cs26 - Ryobi Garden
    Top Expert:
  • Ryobi Master
  • 42,848 Answers
.025" will do the trick
Posted on Apr 10, 2015
moretons
  • 155 Answers
SOURCE: spark plug gap
Normally 25 thou
Posted on Sep 10, 2009
  • 496 Answers
SOURCE: what is the spark plug size and gap?
The "Champion" spark plug for your item is #RDJ7Y
Or another brand, "NGK" #BPMR6F/130-769
You can set the gap to .020"
Hope this helps...
Posted on Sep 25, 2009
wadembly
  • 462 Answers
SOURCE: How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Posted on Jun 28, 2010
panilling9
  • 284 Answers
SOURCE: Can't reassemble Ryobi cs26 string trimmer
https://pivotrim.com/
Posted on Jun 29, 2010
rycgl
  • 1545 Answers
SOURCE: ryobi cs26 trimmer pull cord broke how to
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Posted on May 01, 2011
Testimonial: "very helpful did as you said and it took me less than a hour only my hands got dirty nothing out of my pocket thanks again a+ rated"
What gap should I have ona champion RCJ6Y spark plug for a RYOBI RCS4040CA chainsaw? (40CC).
you should be Googling this yourself, check the model number on the spark plug then google the spec or "spark gap".... that would've been quicker than asking this question.
Aug 26, 2017 | Ryobi Garden
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
What is the spark plug gap for the ryobi 320vbr blower
Hi and welcome to FixYa, I am Kelly.
The spark Plug Gap is 0.030. Any original or aftermarket spark plug for this unit is pre-set to 0.030. Unless you dropped the replacement plug it should be fine. All Ryobi engines 2 and 4 cycle have a 0.030 spark plug gap.
Thanks for choosing FixYa,
Kelly
May 07, 2011 | Garden
Ryobi cs26 won't start
My 39500 will not start. I change the plug and replaced the fuel lins and bubble
Aug 13, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
I have a Ryobi Cultivator, won't run. New spark plug - RZ7C. What is proper gap for plug?? thanks ront
The correct gap according to my RY64400 operators manual is .025 and the torque is 170-190 inch lbs. The spark plug is NGK CMR7A or Champion RZ7C.
Jul 27, 2010 | Ryobi Cultivator
Jun 27, 2010 | Garden
Need to know the spark plug gap for ryobi model no. ry60511A
Ryobi RY60511A
Champion plug RCJ6Y - gap is .22
I have original manual.
Apr 18, 2009 | Ryobi Cultivator
Garden Logo
196 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
