Question about Freezers
The indicator light (that usually reads temp) is flashing, food not frozen
    Top Expert:
  • Freezers Master
  • 42,561 Answers
Check door seals
check power at plug
check thermostat setting in fridge the lower the number the colder the temperature
call a fridge technician
Posted on Apr 10, 2015
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
The freezer is to cold
I do assume this is in Celcius.
-20C is about the right level for a three-star freezer.
From Google:
  1. Domestic freezers have a star rating indicating the temperature they are designed to operate at. On the packaging of a frozen food there is guidance stating how long the food can be stored using freezers of a given star rating. As a guide here are some suggested maximum storage times at -18°C for a variety of foods."
Feb 12, 2015 | Freezers
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Food is not frozen in my freezer and i see water dripping i donot know why
Can you hear the compressor (motor) in the rear of unit running ? Your freezer is thawing out for some reason and i would need to know if there is a digital temp.reading or is it a dile that regulates the temp.
Aug 07, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
99 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
