Question about Stihl Garden
How to stop the oil from leaking from my chain saw
The oil leaks from my MS 192 T C-E Stihl chain saw while not in use.
  • Stihl Master
  • 2,760 Answers
Well this one is a tough one , the mfg answer is too keep all your oil lines and caps new and in good condition , but we all know that's not gonna be very practical in real life , me of course if something is obvious or extreme then sure i'll fix it , but i'll also say most all my saws leak some amount of oil while at rest (and I got more than just a few here too) ,some more than others , so I keep them in saw cases and line them all with absorbent pads that are easy to replace, I have had some limited success in having a Non vented cap to screw on during storage , this works but is a pain to have to switch out just to use saw
Posted on May 21, 2015
stug_57u
  • 99 Answers
SOURCE: cant find serial number on stihl chain saw ms 290
If the silver rating label is still on the safety brake lever, it should be on there. If not, look at teh housing to the left of the exhaust by the 'teeth' on the body, or on the housing below the exhaust. It is normally stamped into the plastic.
Posted on Oct 26, 2008
  • 1388 Answers
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
  • 22 Answers
SOURCE: My Stihl MS-180be chainsaw is leaking a small amount of gas
This saw has a fuel tank vent that could be leaking a small amount of fuel, or the fuel line coming out of the tank could be leaking. Fuel line replacement isn't complicated, you could try installing a new one. If it's the vent, odds are it's not enough to cause alarm........unless the vent line is cracked. In that event, you should replace the vent hose. Again, not a complicated repair.
Posted on Jun 16, 2009
  • 4088 Answers
SOURCE: Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Posted on Jul 08, 2009
  • 154 Answers
SOURCE: not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
Posted on Aug 02, 2009
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
I have a Stihl MS 290, runs great, but the chain keeps tightening it's self on it's own
That's an unusual problem, usually the opposite happens. After making sure the chain brake is off, loosen the two nuts that hold the bar. Be sure to hold the bar up when adjusting the tensioner screw and adjust until the chain is just snug, but not too tight. While still holding the bar up, tighten the two nuts firmly. Check to see that the chain can move freely by hand. Then start the saw and run the chain at speed with something in front of the nose to check for adequate lubrication. You should note a slight fine spray of oil on the object in front of the nose of the bar. Inadequate lubrication, a chain that is binding on the bar, or an overly tight chain can cause the bar to heat up and expand, further tightening the chain. A properly adjusted Stihl saw will use almost all of the chain oil in the reservoir for every tank of gas. Too much oil is better than too little. The oil feed may have to be adjusted for operating in temperature extremes. If operating in very hot conditions, be sure that the saw has not run out of chain oil. The oil feeds faster when hot.
Sep 19, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
Stihl saw leaking chain oil?
Chainsaws can become messy even if the oiler is working correctly. Check the oil level frequently during a cutting session. If frequent refills are necessary, the oiler may be defective
Jun 02, 2013 | Garden
Cannot find oil regulator on stihl 024
There is no oil "regulator" only an oiler with a screw that adjusts the flow, that is found below the saw, and is fit for a slotted screwdriver.
Jan 11, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I HAVE AN O17 STIHL CHAIN SAW AND IT LEAKS CHAIN OIL EVEN WHEN IT IS NOT BEING USED
That can happen. When you go to store it, open the oil cap and then close it to lose the pressure the pump builds up inside.
Oct 01, 2011 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Ms 170 leaks bar chain oil out bottom, no oil on chain
Your clutch drum bearing has gone bad, letting the clutch drum to move around and cut into the oiler behind it, so now it just pumps the oil out that hole. You have to get that fixed to use the saw, otherwise you're going to cause catastrophic damage to the saw very soon.
Sep 25, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
174 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
