Make noise like a relay fault - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valves
Posted on Apr 19, 2015
How to fix a 58 in plasma tv that makes a clicking noise ; no picture
SOUNDS LIKE A FAULTY RELAY HAD THIS FAULT PREVIOUSLY ON SAMSUNG -SONY-TOSHIBA
Jul 25, 2015 | Samsung PN58B560 58 in. HDTV Plasma TV
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
IAC makes a noise when ignition switch is off on 2012 FXDC
Feel all relays to find one that is hot with key off.
Jan 25, 2015 | Cars & Trucks
Piaggio x9. reg 2000. makes a buzzing noise when trying to start. could this be electrical fault? relay perhaps?
Sounds like the starter relay is having some problems.service on these is by replacement only.Disconnect the battery before you start.
good luck
May 29, 2014 | Motorcycles
When the fuel is low a humming sound can be heard for the gas tank area. the second this is that the clicking sound comes from under the passenager side console, and when the clicking sound starts the car...
That humming noise is probably your fuel pump. The pump can be damaged if you always run the car near empty. I would have to say that the clicking noise is probably your fuel pump relay. The relay is probably bad and needs changed. I would say this is the problem. Relays tend to click before they go out. Being that this happens together, I would say the relay is at fault. You might want to check if the relay has a reset on it. I would do this first before I bought a new one. I hope this helps you and best wishes.
Feb 07, 2011 | 1995 Ford Escort
My sony kv-36xbr450 wont come on. When I plug it in I hera a clicking noise and once I press the power button the picture flashes to come on but doesnt and turns off by itself
the main strike relay is turning on the power board but the tube relay is detecting a fault when it trys to ingage the unit needs to be fixed by a lic pro there is no easy fix to this fault
hope this helps
Jan 03, 2011 | Sony KV-36XBR450 36" TV
No clicking sound when I turn on my blinkers and theres no blinking light either
Hi
Most lkely cause of this is either a fuse for the blinkers or the relay which controls the blinketrs, I would be more inclined to check the relay first. this is a small box that plugs into the fuse box, inside it has a small electro magnet, this is the noise you here when you indicate, the clicking noise. if it is not making that noise then it can only be really the trealy or fuse. one other possibility is the wiring but if you have not had any faults previously that will be unlikely.
Hope that helps
Regards
Dan
Sep 30, 2010 | 1993 Nissan Maxima
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
25pt3323 relay chetring
can i possibly get some more info?
Brand?
Model?
and is that the fault of a Relay making a chattering noise??
Aug 13, 2009 | Televison & Video
No flashers or turn signals
Try the fuse/breaker panel under hood, drivers side.
Jun 20, 2008 | 1998 Toyota Camry
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
