Question about Honda Garden
Gcv530 mower starts ok but engine completely cuts out when throttle increases
    Top Expert:
  • Honda Master
  • 45,428 Answers
Check for blocked main jet / water in carby
check fro blocked filter at the tap ( if fitted) or problem needle and seat in the carby.
Posted on Apr 10, 2015
MODEL 961360002 THROTTLE ADJUSTMENT INCREASE
This model is not designed to increase RPM's other than the governor to compensate for increased load during operation. If it's slow I'd check the venturi tube and needle valve in the carb. Doesn't cut well, sharpen or replace the blade. Good luck.
May 16, 2016 | Garden
My hater sprint lawn mower has started to smoke from the engine when being used to cut long grass how can I prevent his?
Increase throttl to max so gas is burned. The hi grass slows mower causin fuel to b tu rich
Sep 28, 2015 | Garden
Husqvarna Proflex 21 just stopped engaging the blades after bump over brick. Was working fine, on starting the next cut the engine goes well, lever works but no mower blades turn when lever lowered. T
Sounds like you have broken a shear pin in the drive pulley.
Shear pins are made to break if you hit something. Other wise it would cost a lot of money to repair the damage.
Jan 24, 2015 | Husqvarna Garden
Troubleshooting
need govenor adjustment and throttle adjustment have to take in 60.00
Sep 04, 2014 | Cub Cadet Garden
Why does my lawn mower start and immediately cut off? Installed new plug and filter.
How long has petrol been in mower for. Could have fuel that has gone bad in it. Also when you start mower you usually need to start with the choke activated until the engine gets warm and then take off the choke. Also check the throttle linkage as some mowers have a device that kills the engine when the throttle is pulled down to stop and it is usually on the mower engine and gets activated when you pull the throttle cable to the stop setting. Had one where this was bent. Another thing I have had is a pin that is in the drive shaft that had broken thus causing the mower shaft not to turn with the engine.
Aug 29, 2014 | Garden
Cuts out when I increase the throttle
Blocked fuel injector in the carb, usually gunk in bottom of tank gets pulled through into carb so idle jet is ok but when you give it the beans the main injector is blocked and the idle jet isn\'t enough to produce increased power demand, ends up just sucking in air only.
also timing, leads, coil. check plug too. Red.
Apr 04, 2014 | 2011 Derbi Senda DRD 125 R
Toro Recycler engine doesn't rev up when control arm is engaged
check the throttle spring in the front of the engine.It is hooked to a loop and when going near a bush it will push in and slow the rpms down.If you locate it pull it out and the RPM"s should increase.
Jul 25, 2012 | Toro Power Lawn Mower
Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Apr 25, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Mower petrol engine runs much too fast
check your governer and spring to make sure it isnt in a bind or being hindered by something
make sure it moves freely
Mar 26, 2009 | Garden
Garden Logo
65 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
