How many square feet is there in an area measuring 700ft x 150ft
    Genius:
  • 1,054 Answers
105000sqft
Posted on Apr 09, 2015
4 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: surface area =300 square feet 25 year old ash
Ash fault? I think you mean "asphalt" but that's OK. You haven't given enough information to solve the problem, but here's what you need to do.
You know the area of the roof is 300 square feet (sq ft). You should know the area of each asphalt shingle, although that's the information you didn't give. When you know that figure, the calculation is very simple:
number of shingles needed = area of roof / area of one shingle
I don't know if this is a class problem, or if you really have a roofing job. Don't forget that on a real roof, the shingles overlap. If you do the calculation, the number you get is right only if you lay the shingles edge-to-edge. A real-world roof would need probably twice that number. Shingles come packed in bundles, and they usually tell you the area they cover. (By the way, 100 square feet is termed a "square".)
Posted on Apr 28, 2011
  • 102366 Answers
SOURCE: Find the area of a square measures know that the
2nd [square-root] 2 . 8 2 ENTER
The square root is the 2nd function of the x^2 key, above and left of the 7 key.
Posted on May 17, 2011
Testimonial: "thanks a lot!"
  • 7993 Answers
SOURCE: The new patio
The figure are similar, corresponding sides are proprtional
L1/L'1=L2/L'2= ... =k , the scale factor for lengths.
However, if scale factor for lengths is k, the ratio of area is k^2 find
Scale factor
Use the given area to find the proportionality factor then use it the ratio of length to find the missing distance between the parallel sides.
Area of new /Area of old=360/250=36/25=k^2
k=SQRT(36/25)=6/5
Ratio of lengths =k=6/5
Distance between parallel sides of new patio/Distance between parallel sides of old patio=6/5
Distance between parallel sides of new patio= (6/5)*12.5=15
The distance between the parallel sides of the new patio is 15 feet.
Posted on Dec 17, 2013
How to convert 200 cubic ft to square feet
Cubic feet is a measure of volume, while square feet is a measure of area. There is no direct conversion between them.
Imagine two rooms that are 20 feet by 20 feet. One room has a ceiling 8 feet high, the other has a ceiling 10 feet high.
Both rooms are 400 square feet, but the first room is 3200 cubic feet while the second is 4000 cubic feet.
Oct 14, 2016 | Office Equipment & Supplies
Calculate cubic feet of stone wall 120'long x 6'-6" high x 3" thick
your measurements are in different units, say feet and inches, you can first convert those values to feet, then multiply them together to get the square footage of the area. If you are measuring a square or rectangle area, multiply length times width; Length x Width = Area.
Aug 23, 2016 | Office Equipment & Supplies
What is cubic feet in 11 feet by 21 feet
You cannot calculate cubic feet from only two measurements. Cubic feet is an area of volume, such as the inside area of a box. With only two measurements you get square feet, which is a measurement of area. A box 11 feet by 21 feet takes up an area of 231 square feet (11 times 21). If the box is 3 feet tall, then you can compute cubic feet since you take all three values and multiply them together. A box 11 feet by 21 feet by 3 feet would contain 693 cubic feet of space (11 times 21 times 3).
Feb 15, 2016 | Office Equipment & Supplies
How to convert room measurement to square feet?
Measure the room in feet, multiply the two together.
12 feet a 8 feet room ? 12x8 = 96 square feet.
Or conversion? See below
Square Feet to Square Meters conversion
Dec 02, 2015 | Carpet Pro Vacuums
How much area is a square foot?
A square foot is by definition 12"x12" or 144 square inches. Measure your area in inches, multiply the length by the width and divide the total by 144 to figure the square feet.
Feb 24, 2015 | Building Materials
How to calculate square feet to cubic feet
Square feet is a measure of area, cubic feet is a measure of volume.
Multiply the area by the height to get the volume.
May 27, 2014 | Texas Instruments TI-30XA Calculator
How many feet is 350 linear feet?
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144:
2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
Apr 08, 2014 | Cars & Trucks
You need to buy fences for your horses but you only have enough for 350 square feet. what is the highest area for 350 sqare feet
Since "square feet" is a measure of area, the area of 350 square feet is 350 square feet.
Or are you asking for the the largest area you can fence off with 350 feet of fencing? With 350 feet of fence material, you could enclose a square 87.5 feet on a side with an area of 7656.25 square feet. Alternatively you could enclose a circular area of a bit more than 9748.24 square feet.
Dec 19, 2013 | webmath.com
How many feet is available in 1000 square metres?
A foot is a measure of length while a square metre is a measure of area.
One foot is exactly 0.3048 metres, so a square metre is about 10.7634 square feet. Thus 1000 square metres is about 10,764 square feet.
Aug 28, 2011 | Office Equipment & Supplies
Conversion
One foot is 0.3048 meters. One square foot is 0.3048^2 meters = 0,9290304m^2. Multiply that by the area in square feet which is 100ft*150ft = 15000 ft^2.
The result is 1393.5456m^2
Jan 24, 2009 | Texas Instruments TI-83 Plus Calculator
k24674
