Question about LG Washing Machines
How to fix LG radio error?
Hello, I have LG LCF600UR car audio player and when I connect it it says "CHECK ANTENNA ON PORT SHORT CIRCUIT". Everything seems to be connected right, but I can't get off this error message. If anyone knows how to fix it pls answer. THANK YOU.
  • 125 Answers
SOURCE: Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
Posted on May 24, 2007
Buffalo12980
  • 625 Answers
SOURCE: Kenmore HE3 F 09 error message.
F09 Overload condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check / Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation Replace failed component.
Posted on Sep 12, 2007
SOURCE: Bose Wave Radio/CD - Sound from only one speaker
had the same problem with the speakers, I am now just using one channel power both speakers, Its not gone on fire yet, not and ideal solution, one channel was driving me mad, and this is free option
Posted on Mar 02, 2008
SOURCE: check camera connection
This happens on my phone also. Its pretty annoying, turning it off and on doesn't work for me. Here's a fix that works for me:
Do a master reset by entering the following key combination from the home main screen: *2767*3855#
**Caution** Back up any files you want to keep, and copy your contacts to your sim card as this will completely reset your phone.
Your camera should work once again.
Posted on Mar 23, 2008
SOURCE: 7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Posted on May 20, 2008
My audio radio does not receive radio stations. what could be the problem. All electrical components work just fine. cassette,CD player works fine but there is no band that will come in on the radio.
Is it a digital tuning? If it is does it auto search but just not find any stations? If this is the case then as J.D.Browning suggested it is an aerial problem! You said there are 2 aerials.....how are they connected to the radio?
Feb 10, 2015 | Volvo Cars & Trucks
Tip
Problems in CB Radio Receive and Modulation
Much of the time complaints about CB receive (RX) and modulation are caused by problems in the antenna system. Make sure there are no shorted or open connections in the coaxial cable or PL-259 (screw-on connectors for coaxial cable, located at the antenna and rear of CB radio) connectors. Use your radio's meter or better still, a Power/SWR meter to check the SWR (Standing Wave Ratio) of the antenna. Try to get that as close as possible to a 1:1 ratio on the meter. A shorted or open antenna can keep the receive audio on your radio at very low levels. Plus, this will harm your transmitter if you continue keying the mike.
Another problem can surface in the radio itself. This will be noticed if you can transmit, but have no "modulation". Modulation can be described as the voice heard above the "carrier" (your transmitted signal). Every CBer knows about the term, modulation. The Truckers will definitely inform you about your modulation quality...lol. This problem can be caused by a defective AMC (Automatic Modulation Control) stage in the receiver circuit. Also, there will be no modulation upon transmit.
One other thing could be causing this lack of receive audio. Defective wiring or switching in the microphone can result in no audio. Additionally, in many radios, a missing mike will not allow receive, because the microphone connection completes the RX (Receive) circuit.
Solutions:
1. Check the antenna system, and fix any problems.
2. Check mike, or substitute another one.
3. Using meter, and/or another radio for listening on same channel, check power and receive.
4. You can probably fix 1, 2 and 3 yourself, or with the aid of a friend.
5. AMC problem in radio (as described above) will require professional service from a CB (Citizens Band) repair facility.
The above suggestions and advice will assist in repairing the majority of the symptoms described.
Regards, Bill
on Sep 18, 2010 | Car Audio & Video
I have a 2012 raptor toy hauler with a sony multi disc player [MEX-DV2200] and the radio has quit working. It turns on but won't receive any stations. Everything else works fine. Any ideas?
Have you been able to check your connections from the unit to the antenna? If it was working before and then just quit I would start there first, a loose connection or frayed coaxial cable could be your problem, also if the antenna has moved it could be improperly grounded now and unable to receive also, you'll need to check the mounting of the antenna to make sure that it has come lose or built up corrsion. Roughly 80-90% of all radio problems/solutions are antenna/cable/connections based and rarely the radio itself.
Oct 16, 2012 | Sony MEX-DV2200
The radio isn't working, I checked the antenna and it is ok. The CD works. I have a Sony CDX-GT300
You may have tuner problem on radio circuit. Please check and get it fixed.
Regards, Jay
Mar 25, 2011 | Sony CDX-GT300 CD Player
I had a 98 toyota tacoma with a completely different radio system and where i used to have perfect service connection to a radio station and now with my 2001 ford focus and the jvc kd-g140 radio i barely...
Hi Sarah,
The problem will lie with one or combination of the radio, the antenna or antenna cable. Check the antenna. If it is the type that can be unscrewed from the body of the car, do so. Check and clean any mating surfaces. Dirt & oxidation are enemies of electrical connections. Check the antenna cable everywhere it is exposed. Look for cuts in the jacket which can allow water in and causes oxidation. Check the connection at the radio, too. Make sure it is free of dirt and oxidation too. Clean the connectors and reconnect. Be sure that the plug connections are fully seated in the jacks. If you find a damaged cable or connector, it should be replaced. many times, replacing the cable will be very difficult - you might want to try installing a new antenna and cable instead of trying to reuse the old antenna. These are often available for sale in the automotive sections of department stores, and in automobile specialty stores. Try connecting everything together to make sure it works before punching holes in the body of the car.
The issue may be the radio itself. Try connecting a different radio - either an identical factory radio that is known to be good - or an aftermarket radio to is also known to be good. All of these issues can be a logical point of failure - especially if you purchased the car used. There's no telling how the car's radio and antenna might have been used or abused before you took ownership of the car.
Nov 22, 2010 | JVC KD-G140 Car CD Player
Will not get good recepiton.
Hi stormnorm157,
Much of the time this is caused by problems in the antenna system. Make sure there are no shorted or open connections in the coax or PL-259 connectors. Use your radio's meter or better still, a Power/SWR meter to check the SWR of the antenna. Try to get that as close as possible to a 1:1 ratio on the meter. A shorted or open antenna can keep the audio receive on your radio at very low levels. Plus, this will harm your transmitter if you continue keying the mike.
Another problem can be in the radio itself. This will be noticed if you can transmit, but have no "Modulation". Modulation can be described as the voice heard above the "Carrier" (your transmitted signal). Every CBer knows about the term, Modulation. The Truckers will definitely inform you about your modulation quality...lol. This problem can be due to a defective AMC (Automatic Modulation Control) stage in the receiver circuit. And, there will be no modulation upon transmit.
One other thing could be causing this lack of receive. Defective wiring or switching in the microphone can result in no audio. Or, in many radios, a missing mike will not allow receive, because the mike connection completes the RX (Receive) circuit.
Solutions:
1. Check the antenna system, and rule that out or fix.
3. Using meter, and or another radio for listening on same channel, check power and receive.
4. You can probably fix 1 and 2 yourself, or with a friend.
5. AMC problem in radio (as described above) will require professional service.
Let me know how this turns out, and inform me if I can offer any more help. Thanks.
Regards, Bill
Sep 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
Makes loud tone when pushing ptt button
The ptt switch or circuit is not disconnecting the audio circuit. Open the unit up and check the wiring, interconnect plugs for something shorted not canceling the receiver audio.
May 10, 2010 | Radio Communications
No signal on Radio,
Start with checking the antenna has an earth connection.
Dec 06, 2017 | Sony CDX-GT210 CD Player
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Washing Machines Logo
119 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
