Question about Onkyo Tx Ds575x - Av Receiver - 5.1 Channel
Hooked up receiver and speakers taken out of storage. All speakers are working via optical cable except the 2 front channel speakers.
Troubleshoot; checked front speakers and wiring by moving connections to "speaker B" connectors and the worked. Is there a way to test whether the front channel is out?
  • 2 more comments
  • Anonymous Apr 11, 2015
    Additional information; I'm trying to hook my Onkyo/ Polk 5.1 home theater up to a new LG LB7200 Smart TV via the optical link. Like said in my original inquiry all speakers center, r/l satellite, & sub are working, but the r/l front speakers are mute. I've searched for possible config setting error, nothing found. The receiver perfect when stored for 10yrs. Are the individual channels internally fused? Any troubleshooting suggestions would be appreciated.
  •  johnny rebel
    johnny rebel Apr 11, 2015
    http://www.intl.onkyo.com/downloads/manu...
  •  johnny rebel
    see pic,substitute center for front
  • Anonymous Apr 13, 2015
    johnny yuma was a rebel too. thanks for assurance that I'd troubleshot the problem correctly. Do you know is the front channels are internally fuse protected, and can I repair?
    Top Expert:
  • Onkyo Master
  • 10,875 Answers
You just checked the front channel,now you know it is out
Posted on Apr 11, 2015
    I agree, do you know if they are fused and easily repaired?
HELP! Surround speakers not working with 5.1 material.
This may sound silly, but . have you checked your sytem setup settings to make sure it is set to 5.1 ,if so then you may very well have a bad channel
Mar 29, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I cant connect my Denon avr 682 to my pc via optical??
I would change your setting on your receiver to digital. its probably on analog. look for a button that says that. You might have to change your input have a look at the rear and see if it says, DVD optical or CD and choose that input.
Dec 09, 2012 | Denon AVR-682 Receiver
Hi, my problem is only the front 2 speakers work i have tried all the speakers in the front 2 connections of the unit & all speakers are working but none when in the rear, center, & sub woofer unit...
Without knowing which receiver etc you have... make sure your "mode" is set to 5 channel, Dolby Pro or similar. And even then, make sure your source is 5 channel. What are you using for an input cable? It needs to be able to provide 5 channel. Standard RCA stereo type cords do not. You need either optical, "coax" or hdmi. Lastly do you actually have a 5 channel program? Many older movies, and standard cable boxes only output stereo, not 5 channel.
May 31, 2011 | Audio Players & Recorders
I just bought an Onkyo tx-s804 receiver. and some new rear surrounds. Since I am moving, have not set up anything formally, but have plugged my dvd player into the front video 4 input via an optical...
PCM is what it's receiving from the DVD player. The player has output bitstream settings, too, maybe even speaker configurations and distances. Read its manual.
May 11, 2011 | Onkyo TX-SR804 7.1 Channels Receiver
I hooked up my newly purchased Sony BDP-S560 with HDMI to my projector for video, optical cable to my Yamaha RX-V750 for audio. I tried several audio setting with the BDP-S560. However,I cannot get any...
It sounds like the BDP unit is set to downmix PCM to the Optical Digital Audio output (the default). You need to change it to something like Dolby Digital. Crack the manual and look at all the digital audio settings you need to choose.
Aug 04, 2010 | Sony STR-DG510 Receiver
I have a LG 42" LCD paired with a LG LHT854 home theater and a directv HD receiver. I the satellite receiver and 854 hooked to the TV via HDMI and the satellitle receiver is connected to the 854 via...
I have an almost exact set-up and you will only get sound out of your rear speakers when the TV channel is broadcasting in 5.1 Ch Stereo. Otherwise the sound is limited to your front, center, and woofer speakers.
Aug 02, 2009 | LG LHT854 Theater System
I've hooked up my LG 47" 1080p widescreen to a LG HE903PAW audio receiver / 5 disc dvd player with upscaling capabilities. I have tested the speaker system and everything's connected properly....
I was talking with LG on virtually the same problem. I have a samsung blu-ray player hooked up via HDMI. Even though the blu-ray is outputting 5.1, 6.1 or 7.1, the LG is only outputting 2 channel unless you switch to pro logic. LG states that this is a known problem and that you are to return the system to where you bought it for a replacement. Call the 1-800 number and they should give you the same answer.
Nov 23, 2008 | Audio Players & Recorders
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Onkyo Tx Ds575x - Av Receiver - 5.1 Channel Logo
185 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
