Question about Air Tools & Compressors
What is angle for framing nails on ATRO CHS 928
    New Friend:
  • 131 Answers
17 degrees I have some left. Nobody carries them anymore!
Posted on Apr 24, 2015
2 Suggested Answers
airnailer
  • 109 Answers
SOURCE: my Paslode framing nailer shoots nails at an angle and will not drive the nails all the way
replace your broken or worn driver
Posted on Oct 04, 2012
D51822 is nailing at a 45 degree angle instead of 90 degree
Joe,
hey not sure what the d51822 brand name is I work on bostitch as a service tech. so well the obvious question with the details you've given 45 degree angle? so are they bent over to get that angle? not sure how they can come out straight and get bent. ok the nose ( where the nail comes out) is it completely flat on the board? if so I would be nearly impossible to create a 45 angle. not doubting you. I work on F28WW bostitch thinking they are similar so, check the bolts on the top (loose or damaged) or the nose its self see if it is bent. it would be only slight because otherwise the driver ( what pushes the nail in) would get jammed and not fire at all .try that first thinking the nose is bent and if its bent its junk. because cracks are next and that's when really bad things happen fast.
Nov 15, 2015 | Dewalt Heavy - Duty 31° Clipped Head...
What is the difference with different angle framing nailer
20 degree are plastic correlated and 28 degree(Bostitch) is wire correlated and 32 degree angle nails are paper tape correlated and lastly coil framing nailers are 15 degrees.
Oct 05, 2014 | Tools & Hardware - Others
How do i load nails in my porter cable clipped head framing nailer...
Pull lever back on top of clip, slip sleeve of nails into slot, then release lever to push nails forward as you use nails.Make sure you are you the right gage of nail.
Jun 18, 2011 | Porter Cable FactoryReconditioned DA250BR...
I was shooting 3 inch nains and I switched to 2 inch. after 20 or 30 nails it failed to drive a nail. The driver makes an indention in the wood but does not drive the nail. What are the problem...
Check that the driver is returning all the way to top of the cylinder. Driver will not return to top when lower bumper is cracked, driver is bent, or piston oring is too loose/tight or low air pressure to gun. Also check that the two inch nail is the same angle as the three in. Place the nails on the outside of the rails with the heads aligned with the rail. The first nail should align with the path of the driver. If the head of the first nail is angled back away from the path of the driver, will miss fire.
Mar 25, 2011 | Stanley Bostitch N88rh Framing Nailer...
What angle nails are used in a frame pro 601 senco
The Senco Frame Pro 601 uses 34 degree clipped head nails.
Nov 23, 2010 | Senco Tools & Hardware - Others
Nail compatibility with Milwaukee framing nailer
any full round head with a 22 degree angle and plastic collated nail between 2 to 3 1/2 inch should work, they don't list any other specific brand but these are the requirements for the tool.
Oct 23, 2009 | Milwaukee Tool Air Tools & Compressors
Check for pproper nails
what is the question, how to remove them and if so I would use a small pick to push them back out the magazine, and also when you get angle nails make sure you use the right guage.
Oct 07, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Air Tools & Compressors Logo
416 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
