Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Air Filter message
Message that we need to clean air filter comes up. We clean the filter but it will not let us press yes that we clean it. Also the temp light keeps blinking. We replaced the bulb in August 2007.
  • 7 more comments
  • dannyboy81 Nov 15, 2007
    i have a panasonic tv model PT60LC14 an it displays a message air filter need cleaning will turn off after 1 minute any sugestions
    the tv shows fine on this problem
  • montt8 Nov 23, 2007
    Same issue, any ideas?
  • fever42 Feb 11, 2008
    my tv is cutting off after 1 minute saying that it needs filter cleaning service what should i do.
  • Phuckie Feb 23, 2008
    Got the same problem. Took the whole damn TV apart. Volume Down + Stop does NOT reset the filter. Try again. I have a pt-60lc14 as well.
    Volume Down + Play did although reset the lamp... whatever that does.
    Maybe give instructions on how to REMOVE the filter. I see the panel to the left (lamp) and the panel in the middle (fan + filter[??]) but i see no way how to remove it. Its screwed in from the bottom and theres no way to remove the screw.
  • Anonymous Mar 27, 2008
    I have the PT-44LCX65 with the same problem. I have cleaned the entire TV but cannot seem to get to the menu to reset the filter. No problem resetting the lamp, but the TV always turns off after about 20 minutes. Remember the good old days when TVs would work for 10-15 years with no problems. Another consumer ripoff scheme from big corporations!
  • Showerr Jul 12, 2008
    my pt60lcx64 got same problem , too.
    i cleaned the filter, but the message still comes out and turns off the tv. How annoying the tv is !
    According to the service manual, in order to get to the filter first
    you must take off lamp, then the back cover, the big fan on the right
    and the whole projection unit. The filter is on the reverse side of
    projection unit.
    so far i almost took the whole tv apart but still cant get it done. if anyone have any suggestion pleast let me know.
  • pana50 Feb 21, 2009
    My remote has a "Swap" button and a "Stop" button, but not a SWAP/STOPkey as mentioned. I tried pressing the Swap and Stop buttons togetherand held down for several seconds, but that did not work. Anyone knowhow to remedy this?
  • wdominique21 Mar 29, 2009
    i have a panasonic pt50lc13 and the message pops up about needed to be filtering and it cut off......wht do i do???
Soulvisitor has it right. I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it. Thank you Soulvistor you saved us at least $100.00
Posted on Nov 04, 2008
  • Panasonic Master
  • 1,113 Answers
Remove silver panel on front marked HDTV and BBE
Open bulb compartment
On the right side of the bulb compartment is the filter compartment
Remove filter and clean
Every 400hours it will prompt to do so.
Comment by Soulvisitor, posted on Jan 03, 2008 Service mode info
Enter Service Mode: With the TV powered off (make sure it's off for a few minutes before trying this, or you'll wait for the customary cooldown period before anything happens if you turn the set off and try this stuff immediately), press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds (they say over 5 seconds in the manual). The TV will be turned on and it will have a screen full of status data atop an active TV channel.
Next, press the SWAP/STOP key on the remote for more than 5 seconds.
You should be taken to a screen that has " LAMP/FILTER/IIC" as a selectable entity. Press the Action key to select it and move to the next screen of info.
You'll see a status screen with the number of Service Mode Resets of the Lamp run time (I inadvertently reset my Lamp to 0 hrs after 95 hours of initial operation, and I'll show you how to avoid that in a minute). You'll also see Total Time, which I assume is total TV run time, Lamp Run Time, and Filter Time, all in hours.
You can backchain to the the prior screens with the Recall button on remote.
To exit this service mode entirely, you must turn off the TV.
You can also enter a different service mode menu to control a number of parameters, as I first learned from Doug McDonald at this link >> when I was trying to learn how to perform service mode color adjustments.
Depress the "Volume Down" button on the set itself while concurrently depressing the "Recall" key on the remote for about seven seconds, and you'll be taken into "Work Mode". At this point, you can press the Action key, and select "Information", where you'll not only see Input mode (as usual) but also Lamp Run Time (but not Filter time or total run time).
You can enter the more advanced service mode menu by pressing and holding the Volume Down button down on the set itself while concurrently depressing the SWAP/STOP key on the remote for more than five seconds. -- This displayed a Factory Adjust menu, with bunch of settings. See Doug's message for more details. (Do not press Vol Down on the set and PIP/PLAY on remote simultaneously, or you'll reset the Lamp time to 0hrs as I did !)
Unfortunately, the service manual does not describe all the tweakable settings in the Factory Adjust menu.......
Nick Stam
PC Mag and ExtremeTech
Posted on Jan 03, 2008
Air filter message on screen
Check your user manual (download if not available) under "cleaning the air filter". It will give instructions on how to reset the filter and remove the message.
Jan 06, 2014 | Televison & Video
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here.
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Fresh air is reading perform cleaning. exactly what does that mean,I cleaned the filter and the plate but it stii reads perform cleaning.HOW
After you have cleaned the filter and plate, reassemble the purifier. Plug it in, turn it on, when the message perform cleaning reappears, press the Reminder Reset button on the purifier to clear the message. Now you are good to go for another 30 days.
Feb 22, 2010 | Ecoquest Fresh Air Air Purifier
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Jan 14, 2010 | Hitachi CP-X201 Projector
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Air filter
air filter message is ussally generated by a tempsensor getting hot. could indicat falulty sensor.. is the fan running. a stalled fan could cause the problem but usaally when that happens it completley shuts down
Jan 29, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Air Filter message
ok you know i would just take it back with the warrenty but heres what i think you should do in the manuel there should be a help line from that brand they should able to help more then me but there should be a compartment at the back where the filter is located if you need anymore help contact me at
Jan 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: Further Questions ?? Email Me Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
10,843 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
