My machine will not agitate but will drain water out. What kind of trouble shooting can I look for & is there a way to get back off? ?
    Top Expert:
  • Washing Mach... Master
  • 43,095 Answers
Call a repairman
Posted on Apr 09, 2015
Testimonial: "Really?? Do you have video on safety switch? I know that's what it Is, please"
  • ray gallant Apr 09, 2015
    try you tube we do not have them
My washing machine wont agitate and the fill light wont come off
whirlpool has manuals and service books for its machines which have a trouble shooting section, try to get one of these. if you have a sears service center nearby you can usually order these service manuals from them pretty cheap
Sep 22, 2015 | Whirlpool Washing Machines
My washing machine will not drain. How can I trouble shoot this. It agitates but will not drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | Kenmore Washing Machines
Water and suds leaking
if you have any suds your either using too much soap or the wrong kind. does the washer drain all the water out each time? is this a new machine where you're washing your clothes in it for the first time? I've seen clothes with resisual soap in them causing over sudsing.
May 20, 2010 | LG WM2487H Front Load Washer
My masher wont stop filling with water or agitate
if water stops coming into machine when you pull the plug you have faulty water level control or the hose going to it.
check the hose for cracks or worn spots, repair or replace.
If the hose is ok you have a faulty control.
If water does not stop when you pull the plug you have a faulty water valve.
You can try dismanling it and cleaning or simply replace it.
Jul 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
Tub will not spin up
It's usually the teeth are broken/worn off the plastic gears. Sounds like one side may be ate up. Check your belts and gears.
Jun 28, 2009 | Kenmore 44072 Front Load Washer
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
Inglis washer won't agitate
Washer/motor runs but wont agitate or spin...this is often a broken motor coupler. See how to take apart info.
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Apr 01, 2009 | Washing Machines
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Trouble shooting kenmore washing machine 80 series.
washer will fill with water that's it, will not operate on any cycle
Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
