Question about Magic Chef Microwave Ovens
I have magic chef microwave it powers on & heats. But when you press 3 it comes up 4 and when you press start it goes back to The time & won't start. Anyone have idea what problem maybe?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 25 Answers
I actually not had that happen before but , when and sometimes I turn it on any number it goes 10 seconds then beep! even when I pressed it longer than 10 seconds , but I don't know but on mine theres a paper there on the side or something metal that tour or broke but , it may be that.
Posted on Apr 09, 2015
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
  • 686 Answers
SOURCE: Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Posted on Apr 12, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
My microwave quit heating. everything seems fine but it doesn't heat
IF YOU ARE A TECHNICIAN THEN OPEN THE OVEN REMOCE TWO WIRES FROM MAGNATRON CONNECT A AC VOLT METER TO THOSE WIRES, PUT THE OVEN ON SET THE TIME FOR 1 MIN AND PRESS START IF 3 TO 5 VOLTS COMES THEN MAGNATRON IS GONE REPLACE IT.IF VOLTAGE IS NOT PRESENT THEN LOOK FOR DIODES AND CAPACITER.
Apr 01, 2010 | Magic Chef MCD1311ST Microwave Oven
I have a MAgic Chef MCM990ST and we've accidently threw away the instruction manual. How do you warm something up for only....lets say 15 seconds?
Press the "Power" button once to select 100% power. Then, enter your time and press the "Start/+ 30 Sec" button. Viola! So incredibly unintuitive that I had to find the manual online.
Jan 24, 2010 | Magic Chef Microwave Ovens
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
Jul 28, 2009 | Magic Chef Microwave Ovens
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
MICROWAVE TURNS ON BY ITSELF AND RUNS FOR 3.5 MIN EACH TIME
My Magic chef Microwave also starts by itself the the keyboard locks up.
We have had this unit for 4 years with no problems. I called Magic Chef and they are sending me a new brain for the unit and then someone will come to my home and repair it. NO CHARGE! I am very pleased that they are backing their product like this. God Belss America
Dec 10, 2008 | Magic Chef CMV1000B Microwave Oven
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
