Avotek router password - Computers & Internet
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Nov 02, 2014 | Zyxel Computers & Internet
Need new password
Which opetaing system and is the password to log on to your computer or an internet connection password ?
How to change your windows password using the command line
http://www.askstudent.com/hacking/how-to-change-your-windows-password-using-the-command-line/
Change a Network Password
A network password is a combination of alphanumeric characters that users must enter in order to access a local area network.
Wireless routers use this password to protect the network from unauthorized users who could potentially steal bandwidth from the network, access sensitive data and view the information being sent to and from the network's router.
To change your network password, you must log on to the router's URL and access its security settings.
Type the router's URL into your web browser.
To access and change any settings on your router, you must log in to the router's URL.
This will allow your computer to communicate with the router and access the router's main page. When accessing the router's URL, use the same computer that was used to install the router.
If you do not know the router's URL, look for this information in the router's manual or on the manufacturer's website.
After entering the URL into the web browser's address bar, press "Enter" or click the "Go" button on the browser.
Input the router's default username and password.
Once you enter the router's URL into your web browser, a dialog box will appear requiring you to input the router's username and password. (Note that this password is not the network password.)
Unless you have previously changed the router's username and password, input the defaults.
Many routers have the default username of "admin" and have the password set as "password" or have no password at all.
To find out your router's default username and password, check the documentation that came with your router or check the manufacturer's website. Click "OK" to proceed to the router's main page.
Access the router's security settings.
Depending on your brand of router, there will be tabs or links on the router's main page.
One of these will contain the page for changing your security settings.
Find and click the link or tab.
This page will contain several textboxes, one of which will contain the SSID (name of the network) and two textboxes for changing the network password.
Select an encryption type and change the network password.
Most new routers offer WEP (Wired Equivalency Privacy) security or WPA security.
Select the type of security and change the network password by typing in a new password in the two text boxes.
When you are finished, click "OK."
Save your changes and log out.
After changing the network password, you must click "Save" or "Apply" to keep the password change.
Log out of the router by clicking the "Logout" or "Exit" link on the router's main page.
If you leave the main page open for a certain period of time, you may be logged out automatically.
Mar 25, 2014 | Computers & Internet
Reset password to the router and get a new one
Are you trying to reset the router password or wireless network password?
Wireless network password is different than router access password.
To change the wireless password, you will need to access the router page and change the settings.
See how to find wireless network password
To change the router access password, you can log in to router page and go to administration tab. There you will find the place to change the router password.
Jan 09, 2012 | Linksys WRT120N Wireless Router
How do i set a password
Router's password could mean 2 things. First password for you to open router's configuration page or password for you to connect wireless to your router.
Configuration's password:
-Logon to your router configuration page
-Please to the TOOLS and ADMIN Tab. You there you can change the admin user name and password. If you do not have the user name and password, please check for the default user name and password on the router's manual. If default user name and password won't work reset the router. Press and hold down the reset button or pinhole on the back of the router for 10 seconds. Then re-enter user name and password again. It should work this time.
Wireless Security Password:
-Under SETUP and Wireless Settings tab you will get an option to change the wireless password
May 21, 2011 | D-Link DIR-615 Wireless Router
I forgot my password
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Oct 31, 2010 | Linksys Wireless-G WRT54G Router
Lost my password
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password.
Oct 24, 2010 | Belkin Computers & Internet
(F5D8231-4) Wireless Router (F5D82314): need password to setup...
May 07, 2010 | Belkin (F5D8231-4) Wireless Router...
Need router and password
  1. Reset router (depress red button in the back of the router for 5 seconds)
  2. Go to 192.168.1.1
  3. Leave username field blank
  4. Enter 'admin" in the password field (without quotes)
Here's a visual
Mar 19, 2010 | Linksys Wireless-G Broadband Router
I am trying to install an HP 7460 wireless printer to my HP cpu via a linksys router. My password for the router is 7 letters, and the printer says it has to be 8 letters. How do I change the router...
When accessing the router’s web-based setup page, a log-in screen will appear asking for the router’s password. The router’s default password is “admin.” You should change the password for security purposes.
The router’s password must be changed to:
  • Prevent unwanted users from accessing the router’s web-based setup page.
  • Enable Remote Management.
The router’s IP password can be changed by:
  • Running the router’s setup CD.
  • Changing it on the router’s web-based setup page. For instructions, please follow the steps below.
Changing the Router’s Password
Step 1:
Access the router’s web-based setup page.
NOTE: If you are using Mac to access the router's web-based setup page.
Step 2:
When the router’s web-based setup page appears, click Administration.
Step 3:
Enter the new password on the Password and Re-enter to confirm fields.
Sep 26, 2008 | Office Equipment & Supplies
CHANGE PASSWORD/ETHERNET ROUTER/WINDOWS VISTA
to make it clear..
change password meaning you need to update your router's password?
SOLUTION: access router's interface and enter correct password information
OR
change password meaning reset your password for your router?
SOLUTION: call router provider/manufacturer ISP to have router's password reset..
Jul 17, 2008 | Alcatel Speed Touch Home Modem
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
